chemical reaction parameters for SiO2 deposition
Old   February 11, 2009, 10:29
Default chemical reaction parameters for SiO2 deposition
Jiuan
Everyone. Right now, I am working on the CFD modeling of SiO2 deposition from SiH4 and O2 by CVD process. To set up the chemical reaction in Fluent, pre-Expotential factor and activation energy are needed. However I can not find these parameters from the available references. Do you guys have any suggestion to find these two parameters? Thanks in advance.
Jiuan
Old   February 25, 2009, 02:11
Default Re: chemical reaction parameters for SiO2 depositi
sathees kannan
These 2 parameters are must for specifying chemical reaction, since it is the one which determines the Rate of generation or rate of depletion of any species. If you cant able to get proper reference. these parameters can be found with simple experiments even.
Old   February 25, 2009, 02:19
Jiuan Wei
Thanks for your reply. Actually I have searched some reference, but can not find these two parameters. In my current lab, we do not have equipment to do the simple experiments. However I believe this chemical reaction has been studied a lot before since it is a classic one, but maybe because the reference is old, therefore it is not easy to find them.
Old   August 18, 2009, 02:01
student
JuJu is on a distinguished road
Hello, I'm a Belgium student and I am also looking for the same data for some homework I've to do.
My professor told me that these data were easy to find but I'can't find it I'tried to serch the net or to search scientific publications but every time I found thousands of results but I could not find the answer to my question.
The most interesting content I found is this post and I hope you got some solution since you initially post it.
If somebody can help me?
Thanks
JuJu is offline   Reply With Quote
species deposition or wall reaction ? gianfilippo FLUENT 2 August 21, 2012 14:19
chemical vapor deposition philip FLUENT 0 March 17, 2002 14:35
chemical vapour deposition Rajani Kumar Main CFD Forum 10 August 23, 2001 14:33
chemical vapor deposition Paul Izabel FLUENT 0 May 7, 2001 06:45
Chemical Vapor Deposition problems??? Chuck Leakeas Main CFD Forum 1 September 3, 1998 17:35
