Array problems
Old   February 10, 2009, 12:43
Default Array problems
Malachy
Colleagues,
I would be interesed in any suggestions on the following. I am using Fluent 12 beta release. Below is part of a udf to define a periodic boundary condition at the inlet. I've had this bc working in earlier versions of fluent. My problem concerns the initiaisation of a number arrays at the beginning of the routine.
The routine starts by intialising the arrays radexp, a0, a and b. The routine compiles, builds and loads ok using ms visual c++ 2008.
On intialising the flow field using the compute from 'inlet' the routine appears to read (from file) and write (to screen) the arrays radexp, a0, a and b correctly. However when I try to write a after reading b the elements of a become jumbled. This coding worked fine on versions of fluent prior to 6.4. Any help, suggestions greatly appreciated. I have tried reading and writing the arrays using pointers but I get the same result.
#include "udf.h"
#define M 128
#define N 13
DEFINE_PROFILE(inlet_velocity,thread,index)
FILE *fp;
int i, j;
float radexp[25], a0[13], a[128][13], b[128][13];
float x[ND_ND];
face_t f;
float xcoord, ycoord, zcoord, radcfd;
fp = fopen("PBFFT12.txt","r");
for (i=1; i<N; i++)
fscanf(fp, "%f", &radexp[i]);
radexp[i] = radexp[i] * 0.001;
for (i=1; i<N; i++)
printf("%12.8f ", radexp[i]);
printf("\n");
for (i=1; i<N; i++)
fscanf(fp, "%f", &a0[i]);
for (i=1; i<N; i++)
printf("%12.8f ", a0[i]);
printf("\n");
for (j=1; j<M; j++)
for (i=1; i<N; i++)
fscanf(fp, "%f", &a[j][i]);
for (j=1; j<M; j++)
printf("%4d ", j);
for (i=1; i<N; i++)
printf("%12.8f ", a[j][i]);
printf("\n");
for (j=1; j<M; j++)
for (i=1; i<N; i++)
fscanf(fp, "%f", &b[j][i]);
for (j=1; j<M; j++)
printf("%4d ", j);
for (i=1; i<N; i++)
printf("%12.8f ", b[j][i]);
printf("\n");
for (j=1; j<M; j++)
printf("%4d ", j);
for (i=1; i<N; i++)
printf("\n");
fclose(fp);
begin_f_loop(f,thread)
//NB. this is just to return a value, not the bc.
F_CENTROID(x,f,thread);
F_PROFILE(f,thread,index) = 0.02;
end_f_loop(f,thread)
Old   February 10, 2009, 13:43
Default Re: Array problems
Malachy
Please note I'm having trouble putting in the less than symbol. All i loops are evaluated between 1 and N-1, and all j loops between 1 and M-1.
Old   March 5, 2012, 16:11
Yolk
Yannian is on a distinguished road
have you succed using array for the inlet boundary?
Yannian
Yannian is offline   Reply With Quote
array in UDF Kamal FLUENT 1 November 7, 2013 02:15
can we initialize an array in UDF? blueberry Fluent UDF and Scheme Programming 2 April 14, 2009 13:00
UDF array problem Malachy FLUENT 0 February 10, 2009 11:41
Array of fields r2d2 OpenFOAM Running, Solving & CFD 11 January 30, 2008 13:40
Why I can not allocate five 256*256 array in VC++ Aspens Main CFD Forum 4 March 1, 2000 05:06
