'Tetrahedral meshing has failed for volume...'
Old   February 6, 2009, 17:14
Default 'Tetrahedral meshing has failed for volume...'
Murat
My question is related with Gambit. I am doing some modifications on 3D truck model. One of this modification is adding side mirrors to truck. I created the side mirrors on truck geometry and meshed the all surfaces of side mirrors one by one. Then i wanted to create volume mesh on the geometry but it did not mesh the volume and it gave an error on the text screen of Gambit like this; "Tetrahedral meshing has failed for volume v_volume.57. This is usually caused by problems in the face meshes check the skewness of your face meshes and make sure the face mesh size are not too large in areas of small gaps."
Before adding the side mirrors to truck geometry, there were no error on meshing the volume. So, i guessed that the error was related with side mirror geometry. But, although i check both faces and face meshes of side mirror geometry, there is no error message related with them. Furthermore, what can be the reason for not meshing the volume? What can i do to mesh the volume?
Thanks,
Murat
Old   February 9, 2009, 21:07
Default Re: 'Tetrahedral meshing has failed for volume...'
zongtwi
Try using size functions around the side mirror geometry. See if that would help.
Old   February 10, 2009, 01:45
Murat
I tried size functions but this time Gambit gives error message like that: " TG_Mesh Domain failed with error code 1. A size function is already associated with the following entities, thus the required uniform mesh size is ignored during meshing"
I did not understand what this message mean. Before i did not try size funtion on geometry but the error message mentions like that.
Old   February 10, 2009, 04:49
zongtwi
Well, it is hard to troubleshoot your case without seeing the problem first hand.
I would recommend re-meshing your case from scratch. Do a 'Reset Mesh' in the command line, and mesh your edges, surfaces and volumes again. Ensure that your sizing are all similar to the previous case if you want to compare the two results together.
Hope that helps.
Old   February 10, 2009, 07:36
mAx
you should have an small egde somewhere
Old   February 19, 2011, 05:22
bing
onionmon is on a distinguished road
I had the same error. I discovered a vertex from one surface that was very close to another surface so that a 3D tet element was not able to be created during 3D meshing. The vertex closeness to a surface is shown in a rough diagram below.
|       |_._|       |
See if you can find a lone white vertex (multi-edged vertices are purple) sitting by itself anywhere in your model. Zooming out may help. I then created a geometry and boolean-subtracted it from my base geometry so that the vertex was removed. Then I was able to mesh.
onionmon is offline   Reply With Quote
Tetrahedral vs. Hexahedral Meshing for CFD Andy Bartels Main CFD Forum 16 September 20, 2019 11:06
Failed in volume meshing MANOJKUMAR FLUENT 0 October 19, 2005 07:19
tetrahedral meshing in square channel Aashutosh Magdum FLUENT 4 May 28, 2005 21:27
Initialization failed for volume meshing?? Ng FLUENT 1 March 15, 2005 09:00
tetrahedral meshing Codes Heinz Wilkening Main CFD Forum 1 August 26, 1998 15:03
