Engine Inlet problem
Old   February 4, 2009, 05:02
Default Engine Inlet problem
Alfonso
Hi everyone I have some trouble simulating a Engine Inlet system with fluent in 3D My CFD set up is velocity of Air inlet 60 m/s and and turbulence model that I using is k-epsilon teh simulation goes well but on the fluent panel appear reverse flow in several faces Can anybody help me what does mean and how can I solve this problem? thank you so much Alfonso
Old   February 4, 2009, 05:14
Default Re: Engine Inlet problem
pramod
hi reverse flow means flow is coming out from inlet surface when u create one surface in inlet plane and display vector u can see how flow become reverse . remedy: check u r boundary con. try for redusing inlet velocity
Old   February 4, 2009, 10:05
SA
why dont you create the natural boudary condition at inlet of your inlet.,that is the static far field.
Regards
Old   February 4, 2009, 16:38
John S.
Also, if you're running a boundary layer simulation those reversed flow faces are most likely sitting within the BL where the near-wall velocities are near zero.
Old   February 11, 2009, 10:22
Alfonso
Hello Pramod, SA and Jhon.S thank to you all I will test your advice I hope to solve this problem because I donīt what is happening could you please pass my any tutorial about Intake Engine Air System Thanks to you all again Regards
Old   February 16, 2009, 11:26
SYED AMEER BASHA
hai,
I am trying to simulate diesel engine.i am at the begining stage please any body send tutorial which covers
1)Creating diesel engine with inlet,outlet valves and piston. 2) Creating a sliding/moving mesh 3)Simulating a diesel engine
problem with inlet BC Razio FLUENT 1 December 19, 2007 10:11
cfx-pre: inlet problem student CFX 1 April 21, 2006 06:56
Negative densities found ina an I.C engine problem varun Siemens 5 June 2, 2005 03:03
FLOW THROUGH AN ENGINE INLET VALVE TOM FLUENT 0 November 5, 2001 11:42
modelling airflow through an inlet restrictor on a four stroke engine mike ede Main CFD Forum 0 October 8, 1999 10:06
