Problem in tutorial 12
Old   January 28, 2009, 11:23
Default Problem in tutorial 12
mrestrepo30
I'm working on Tutorial #12 from the Fluent CD, and I can't go on after loading the UDF valve.c because this message keeps appearing:
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
Does anyone knows what I might be doing wrong???
Thanks!
Old   January 28, 2009, 12:18
Default Re: Problem in tutorial 12
KJ Larsen
Hello
Is this the first time you've used a UDF? On windows machines you need to launch fluent from the command prompt if you are using UDFs. (Under Programs -> Fluent Inc there should be Set Environment, after clicking on this you can launch Fluent by typing fluent, (perhaps followed by 2d/3d/2ddp etc.) into the command prompt, from any directory). Otherwise are there any errors above that in the compilation? This also would stop the library from being loaded.
Does this help? Kris
Old   January 29, 2009, 01:09
Davy
if u want to load the library, you must install a C language compiler first and set the environment as instructed.
Old   January 29, 2009, 09:11
Default diesel problem
Balashowry
sir,
How to model diesel engie in gambit.suggest me some examples.If you have any problems please send me.waiting for your valuable reply. Thank you.
Old   January 30, 2009, 11:37
mrestrepo30
well, after doing all you said, I'm still getting the same error....
and there are no more errors above the compilation.
Thanks anyway!
Old   January 30, 2009, 12:11
KJ Larsen
Hello again
Does Fluent build a folder in your working directory called libudf containing scr and ntx86 folders? scr should have the a copy of the .c files you compiled from your working directory.
I had some problems creating the library on a 64bit machine as Fluent wanted to put the makefile etc. in a different folder.
Cheers. Kris
Old   January 30, 2009, 12:14
mrestrepo30
yes, the scr and ntx86 folders are created. scr has the copy of the .c file.... but still nothing.
thanks!
Old   February 2, 2009, 07:54
naga
if u wanna use UDF u should have visual studio (SDK).and while opening dont keep the folder in desktop
Old   July 18, 2010, 14:59
Dave Smith
davesmith_01 is on a distinguished road
Hi
Did anyone get the UDF to load, I can build the file valve.c, but when I click on load it gives errors and then I cant hoook the function.
Can anyone please help with the matter, I have MS visual studio 2008 installed and am using fluent in win xp 32bit.
Does anyone know why this is not working when asked to load?
Please help
Thanks in advance
davesmith_01 is offline   Reply With Quote
XiFOAM tutorial Problem 21kalee OpenFOAM Running, Solving & CFD 0 April 22, 2008 19:18
Problem of CFX tutorial 13 Susan CFX 2 January 2, 2008 03:34
Problem with icoDyMFoam tutorial matlie OpenFOAM Bugs 10 April 26, 2007 05:51
Problem in Tutorial problem of fluent Phanindra FLUENT 5 April 17, 2007 10:57
Problem in Tutorial 11 Leon Siemens 5 December 20, 2006 07:06
