how to give heat dissipation from wall
Old   January 28, 2009, 06:27
Default how to give heat dissipation from wall
aravind
hi,
im modeling air flow in between two vertical plates which are maintained at 10C inside which there is a phase change material with a latent heat of 180 kJ/kg to cool the air. air temperature is 25C. the phase change material is constantly removing some amount of heat from the air. how to model the heat dissipation from the wall.
HOW TO GIVE BODY HEAT GENERATION TERM NITUL KALITA FLUENT 3 December 18, 2008 12:23
wall & wall shadow net heat flux Barbaros FLUENT 1 August 5, 2006 03:00
heat dissipation shani FLUENT 0 March 11, 2005 01:56
VISCOUS heat dissipation Joseph CFX 0 October 1, 2004 09:52
Viscous heat dissipation muhammad asif Main CFD Forum 0 July 25, 1998 05:00
