Unsteady Boundary Profile with data file
Like Tree6Likes
Old   August 7, 2012, 11:00
MINNESOTA
parvin is on a distinguished road
Hi MAX
Thank you for your help.
Could you please tell me where I should write a profile, actually I'm getting confused, Should I create through define profile option in Fluent or I can creat by myself in a text format and then saved it and uploading it in fluent? Thank you so much..
Originally Posted by -mAx- View Post
parvin is offline   Reply With Quote
Old   August 8, 2012, 01:33
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
in 6.3 you could create your profile as text file, or also in Fluent
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 2, 2013, 23:04
Default Udf
  #23
amaly is on a distinguished road
I need the UDF
amaly is offline   Reply With Quote
Old   July 3, 2013, 09:49
Victor
VictorLP is on a distinguished road
Hello.
I have simulation divided into two steps.
To set a boundary condition as transient profile in second step i need to write this transient profile during calculation of first step. Or may be i can compose this profile, using resulting .dat files? But i can't find how to do it automatically.
I know how to write simple profile (x y z parameter1 parameter2) but it is not transient. It is very hard to open all dat files and save profiles and then compose full transient profile.
Thank in advance for all help.
VictorLP is offline   Reply With Quote
Old   March 24, 2014, 05:15
Default profile file doubt
  #25
amit
akjha is on a distinguished road
there is a good help on this thread, but i have a doubt
if my simulation has run for 1000s and now i want to change my pressure outlet BC by giving a profile should my first point be pressure at 1000s or i should start from 0.
akjha is offline   Reply With Quote
Old   March 24, 2014, 06:52
Victor
I not fully understand what you mean. But if you have already calculated 1000s and you want to continue with new BC profile, you just can read profile with data like this for example
time
1000
2000
3000
pressure
500
700
1300
or like this if your BC was steady
time
0
999
1000
2000
3000
pressure
30
30
500
700
1300
and you can continue your calculation.
But problem is in difference between your outlet bc until moment 1000s and after. If difference is significany it may be a problem.
Old   March 24, 2014, 06:55
amit
i got the answer, thank you very much.
Old   August 9, 2015, 15:56
Default Coordinates
  #28
Christian Mahr
chri is on a distinguished road
Hi everybody,
I am facing a problem including pofiles as well. I managed to create a .prof file in the correct format where I put velocity magnitudes for the use as a velocity-inlet profile. As it is a point profile, I have to give it the point-coordinates.
To which coordinate system does it refer?!
my geometry is kind of complex so the points are situated somewhere I dont really know about coordinatewise, reffering to the global coordinate system.
can I read specific coordinates out of the geometry?!
all the best,christian
chri is offline   Reply With Quote
Old   October 29, 2016, 16:24
Default help wanted
  #29
mike
shalamike is on a distinguished road
Hi there,
I am fairly new to ansys fluent and I need to create a tabular transient profile for a two phase flow system with fuel vapor going into a cylinder from a very small inlet. The velocity profile of the fuel is not constant as it needs to create vortex rings so adjusting for time will be the easiest way to do it.
however i don't understand all the aspects to the table form and my first try at making this table does not seem to show on user defined profiles for inlet after i read the profile.
my transient table looks like this so far
inlet 2 6 0
time velocity
0.1 0.0000008
0.2 0.0000800
0.3 0.0080000
0.4 0.8000000
0.5 0.0008000
0.6 0.0000008
(could someone also please explain what these 3 numbers next to the profile inlet is meant to represent, i know this may seem like a stupid question but have my own interpretations and i could easily be wrong)
Would this table be sufficient for two phase flow (correct format excluding the brackets)or would i have to add something extra to specify which phase this will apply to. Also could someone please instruct me on how to read this on ansys from notepad, i tried using the text command to read transient table and ansys says its reading file but nothing happens, any advice?
Any help will be appreciated.
shalamike is offline   Reply With Quote
Old   December 6, 2016, 08:02
Onur Özcan
oozcan is on a distinguished road
how can we create unsteady tabular boundary conditions?
I could not see anywhere to write it?
time velocity
0 5
3 0
6 5
9 0
12 5
... going on so,
oozcan is offline   Reply With Quote
Old   April 30, 2017, 10:20
Sadia
khattaksadia is on a distinguished road
Originally Posted by person
;156255
Here is the answer to your question
Standard Transient Profiles
The format of the standard transient profile file (based on the profiles described in Section 7.26) is
((profile-name transient n periodic?) (field_name-1 a1 a2 a3 .... an) (field_name-2 b1 b2 b3 .... bn) . . . . (field_name-r r1 r2 r3 .... rn))
One of the field_names should be used for the time field, and the time field section must be in ascending order. The periodic? entry indicates whether or not the profile is time-periodic. Set it to 1 for a time-periodic profile, or 0 if the profile is not time-periodic.
An example is shown below:
((sampleprofile transient 3 0) (time 1 2 3 ) (u 10 20 30 ) )
This example demonstrates the use of crank angle in a transient profile
((example transient 3 1) (angle 0.000000e+00 1.800000e+02 3.600000e+02) (temperature 3.000000e+02 5.000000e+02 3.000000e+02) )
All quantities, including coordinate values, must be specified in SI units because FLUENT does not perform unit conversion when reading profile files. Also, boundary profile names must have all lowercase letters (e.g., name). Uppercase letters in boundary profile names are not acceptable.
You can read this file into FLUENT using the Boundary Profiles panel or the File/Read/Profile... menu item.
Define Profiles...
File Read Profile...
See Section 7.26.3 for details.
Tabular Transient Profiles
The format of the tabular transient profile file is
profile-name n_field n_data periodic? field-name-1 field-name-2 field-name-3 .... field-name-n_field v-1-1 v-2-1 ... ... ... ... v-n_field-1 v-1-2 v-2-2 ... ... ... ... v-n_field-2 . . . . . v-1-n_data v-2-n_data ... ... ... ... v-n_field-n_data
The first field name (e.g. field-name-1) should be used for the time field, and the time field section, which represents the flow time, must be in ascending order. The periodic? entry indicates whether or not the profile is time-periodic. Set it to 1 for a time-periodic profile, or 0 if the profile is not time-periodic.
sampletabprofile 2 3 0 time u 1 10 2 20 3 30
This file defines the same transient profile as the standard profile example above.
If the periodicity is set to 1, then n_data must be the number that closes one period.
periodtabprofile 2 4 1 time u 0 10 1 20 2 30 3 10
The following example uses crank angle instead of time:
example 2 3 1 angle temperature 0 300 180 500 360 300
All quantities, including coordinate values, must be specified in SI units because FLUENT does not perform unit conversion when reading profile files. Also, boundary profile names must have all lowercase letters (e.g., name). Uppercase letters in boundary profile names are not acceptable. When choosing the field names, spaces or parentheses should not be included.
You can read this file into FLUENT using the read-transient-table text command.
file read-transient-table
After reading the table into FLUENT, the profile will be listed in the Boundary Profiles panel and can be used in the same way as a boundary profile. See Section 7.26.3 for details.
Thank You for your insight about tabular transient udf. I'm also trying to implement it in my udf. I need to apply gaussian heat flux using temporal udf. I've calculated the heat flux for each time. I could understand by your example how to frame a particular command (tabular transient udf) but I'm unable to get how to use it.
Can you please post a complete example of udf starting from the first step (#include "udf.h") till last step i.e.
(end_f_loop(f,t)
using tabular transient udf.
Thanks in advance!
khattaksadia is offline   Reply With Quote
Old   May 6, 2017, 05:28
Sadia
;156255
Define Profiles...
Can we use the same for temporal yet steady state profile too?
Old   May 7, 2017, 05:18
Default Transient 3D for finite volume methods
  #33
SGrozny's Avatar
Sahidah Grozny
SGrozny is on a distinguished road
Assalamualaikum wr. wb
good morning,
i've problem in formula numerical analysis for my script?
if my (simulation) condition is 3D Transient at cylindrical pipe 3/4 inch.
thanks before, Have a good activity guys.
SG
SGrozny is offline   Reply With Quote
Old   September 27, 2017, 09:54
Default Reading Transient Tables
  #34
Ujwal Rajan
ujwal rajan is on a distinguished road
Hey guys,
I am using fluent and matlab to run a fluid structure interaction over an airfoil. I am making use of matlab to feed all the commands into fluent and perform the necessary actions.
I have to input the profile for a gust of wind at the inlet (which is a pressure-farfield) in my case.
i have used the following command in matlab to input the gust:
fprintf(fid,'(ti-menu-load-string "file interpolate read-transient-table " "
\\n")\n');
However, i do not know what to fill in after using the command read-transient table. Also, how do i specify on what zone the profile has to be used in??
Any help is massively appreciated!
Thank you!
ujwal rajan is offline   Reply With Quote
Old   July 29, 2019, 17:35
Abdullah Tariq
madmechanic is on a distinguished road
Hi, I am also trying to use a transient tables to apply my boundary condition. However when I type in the following commands into the ansys console
file
/file>read-transient-table
transient-table file name [] (insert name)
ANSYS displays the error shown below. I made file on wordpad using the correct format and saved with txt extension. I saved the file to my desktop. Can you help me with this?
Error: File "insert name" not found!
Error Object: #f
madmechanic is offline   Reply With Quote
Getting Time Series data from saved unsteady data Atul FLUENT 4 November 26, 2008 06:12
applying profile data as a boundary condition vadivel CFX 1 June 9, 2007 08:11
file/write-profile ... journal file MM FLUENT 5 November 30, 2006 04:07
2D setup and 2D profile data file in CFX10 Se-Hee CFX 3 October 30, 2006 10:49
Profile Data Velocity Boundary Condition Changes?? Maria Angelica CFX 9 June 14, 2006 03:44
