model of pipes inside pipe
Old   January 22, 2009, 10:27
Default model of pipes inside pipe
carmen
I 'm modeling by GAMBIT_FLUENT a system that consists of: two vertical steel pipes (D=0.08m L=1000m)(iside the pipes happens a flow of hot gas); another pipe (D=0.2m L=1000m) contains the two pipes and is full of water;
I can use a 2D model (vertical section)? In this way I lose some informations? THANK YOU!
K-Epsilon model inside VECTIS Ilomem Main CFD Forum 0 October 24, 2008 00:53
To model fire inside the domain - please help hari Main CFD Forum 0 October 27, 2007 09:35
How to model intersecting pipes Ankush Aggarwal Siemens 2 June 8, 2006 10:33
Flow in a Pipe having protrusion inside it Hari Analakkat Main CFD Forum 0 January 25, 2006 07:22
Double surface inside model Andrew Siemens 1 March 16, 2005 00:04
