January 20, 2009, 11:42 |
moisture flow in wall assembly
Hello, I am trying to study heat and moisture flow in a wall assembly with an insulated cavity. I'm using the species model, and setting the mixture as air and H2O. I know I have to provide a moisture mass fraction for the inlet, but I don't know how to do that. I don't have an inlet. My boundary conditions are an exterior and an interior surfaces with set temperature (set as walls). The only place where I can set the mass fraction is in the insulation cavity, but I want to see how the moisture coming in distributes in the insulation cavity, so it doesn't make sense to give initial conditions there. Any help with this is appreciated...
Thanks Saba |
meshing assembly in gambit | corey | FLUENT | 19 | May 30, 2009 07:40 |
Proam: Assembly | Bala | Siemens | 1 | March 15, 2008 21:21 |
CFX-Block or Assembly? | Susan | CFX | 0 | November 20, 2007 06:23 |
Grid Assembly | Mir | Siemens | 5 | April 24, 2002 07:59 |
assembly coding for CFD | Andrei Chernousov | Main CFD Forum | 4 | November 9, 2000 10:33 |
