solution convergence problem
Old   January 18, 2009, 04:39
Default solution convergence problem
anbuselvan
I am simulating the internal flow through a scramjet engine.
Desired analysis type: 2-D steady viscous-laminar
Inlet condition: pressure far field
Pressure: 48Pa
temperature: 67K
mach number: 8
The geometry consists of convergent type inlet followed by constant height combustion chamber and the divergent type nozzle. width is constant throughout. Since the geometry is symmetrical, i tried the simulation with 2-D symmetry condition.
Solver details: coupled, second order upwind discretization implicit scheme.
I meshed with gambit using unstructured (pave scheme) quadrilateral elements. The solution is well converged for inviscid case. the residuals went beyond 10e-12, but the solution didn't converge for viscous case. the X-momentum residuals starts oscillating at 10e-4, then Y-momentum oscillates, then energy and continuity. sometimes it blew up if i continue to simulate.
what could be the possible reasons for it?
Old   January 18, 2009, 05:00
Default Re: solution convergence problem
Antimony
If you are interest is in looking for the lift and/or drag coefficients, you might want to keep an eye on them instead of the residuals. Sometimes, it is not possible for the residuals to go below a certain value. Check that the lift/drag or any other coefficient that you are monitoring is at a steady value.
Alternatively, you can probably start with a first order scheme and then switch to higher order after this has reached a desired convergence value. And if you are using, the pressure based solver, you might want to switch to the density based solver and give it a shot.
Solution Convergence Ken Adams FLUENT 10 May 17, 2007 06:48
General Unsteady solution convergence Freeman Main CFD Forum 0 December 7, 2005 18:08
convergence of solution question julie FLUENT 4 November 14, 2005 09:35
Solution convergence nick FLUENT 2 February 26, 2001 13:41
problems with solution convergence Roberto Ciardulli Siemens 12 October 29, 2000 04:36
