Solidworks IGS to Gambit Problem
Old   January 16, 2009, 09:28
Default Solidworks IGS to Gambit Problem
Mustafa Ayad
Hi all i make a 2D model of Spur gear in Solidworks 2008 and save as IGS file and when i try to import it to gambit this error messade appear : GEOM-TRANSLATION LICENSE i want the solution for that Regards.
Old   January 16, 2009, 13:23
Default Re: Solidworks IGS to Gambit Problem
Iván
Hi, it is for the license, the original license can import or export the IGS files , however there is a form with Catia v5, save as SAT file, your 2d model import to catia V5 and after open in the gambit.
sorry for my english, I´m learning. ,
Regards
Old   January 16, 2009, 13:48
Mustafa Ayad
Hi but a can not find SAT file in Catia V5 Regards
Old   January 16, 2009, 14:29
Iván
sorry Mustafa, the file is STEP or STP, save the file in catia v5 and after open the gambit in FILE - IMPORT - STEP, and open de file.
Iván
Old   January 16, 2009, 14:35
Mustafa Ayad
sorry Ivan the same error is remain ,please send to me your privet E-mail to send to you the error as a picture. Regards
Old   January 16, 2009, 14:36
Iván
ok my friend my e-mail is: tristan_rips19@hotmail.com
Old   January 16, 2009, 14:41
Mustafa Ayad
i send to you an email if you can to give me your Tel number
Old   January 18, 2009, 06:26
Jasbir Singh
For importing a solidworks component (parasolid, step, iges, all others) i need the geom-trans license file. is there anyone who can help me out here please???? none of the above steps are working. same thing happened with my unographics software too...please help!
Old   January 18, 2009, 13:21
Will Humber
I would contact your network administrator or contact fluent directly. Alternatively, if you're using a cracked version of fluent then you're SOL.
Solidworks --> Gambit Sandeep ANSYS Meshing & Geometry 16 August 18, 2015 02:06
SolidWorks to Gambit Chris FLUENT 0 November 6, 2005 18:15
solidworks to gambit Alex FLUENT 2 March 25, 2005 09:06
Importing Solidworks drawings to Gambit Lior FLUENT 3 February 4, 2005 17:43
