Counter flow HX
Old   January 14, 2009, 03:53
Default Counter flow HX
moh
Hello guys, I am trying to simulate a counter flow heat exchanger with known inlet temperatures and velocities. wall thickness is to be considered as well.
I am having a problem in setting the outlets bc. if i set them to pressure outlets i have to key in the outlet pressure which is one of the things i am looking for in this simulation.
one more problem is in the walls between the 2 fluids (the wall and the shadow wall)what is the best bc to be used here?.
I would really appreciate your help in these problems
Thanks
Supersonic flow past a wedge with counter flow Mahesh Bailakanavar FLUENT 0 February 14, 2008 01:21
Counter flow heat exchanger with two different liq Ram Dayal CFX 3 August 6, 2006 21:42
Turbulent counter-flow cristion FLUENT 5 October 7, 2005 10:47
what boundary do I choose for the counter-flow ? Gali FLUENT 0 October 20, 2004 06:44
I need thesis or papers on counter flow Mahibooswami Main CFD Forum 0 June 6, 2003 19:25
