January 8, 2009, 18:25 |
Fluent - boundary conditions
let us assume a flow in simple pipe (air). Step 1: I used mass flow rate boundary condition at inlet and outflow boundary condition at outlet. I calculated pressure values at inlet and outlet in post processing step.
In step 2 , I used the above obtained pressure values as my pressure inlet and outlet boundary conditions respectively. Now question is I am not getting the same mass flow rate at inlet as in step no. 1 |
Re: Fluent - boundary conditions *NM*
January 8, 2009, 22:02 |
Which pressure did you calculate, static or total from case 1?
January 9, 2009, 12:42 |
At inlet I calculated total pressure and outlet I calculated static pressure
Boundary conditions in Fluent | Ankan Kumar | FLUENT | 5 | November 9, 2016 04:44 |
Fluent-Boundary Conditions | Vijay | FLUENT | 4 | March 20, 2016 12:12 |
Boundary conditions in Fluent. | Novice | FLUENT | 5 | March 20, 2016 12:10 |
Fluent 3D Boundary Conditions | ABM | FLUENT | 2 | February 17, 2009 12:41 |
Boundary conditions in Fluent 4.5 | Arturo Ortiz | FLUENT | 0 | January 25, 2001 18:52 |
