v2f Turbulence Model (and others?)
Old   January 5, 2009, 14:25
Default v2f Turbulence Model (and others?)
Travis
Two questions:
1. Does anyone have any case studies that would help determine the accuracy of the v2f turbulence model for highly turbulent flows? I'm trying to decide on a turbulence model for a circulation-control wing.
2. What other turbulence models are built into FLUENT? I only found out about the v2f model recently and I'm wondering if there are others I don't know about.
Thanks,
-T
Old   January 6, 2009, 02:08
Default Re: v2f Turbulence Model (and others?)
selvag
some Low Reynolds Number (LRN) version of k-e models also available in fluent.
Old   January 6, 2009, 15:55
Travis
Any idea how to activate them? I know the command for the v2f model is (allow-v2f-model).
Old   January 7, 2009, 00:25
selvag
To enable LRN k-e. First choose the std k-e model and then type the following in the console window define/models/viscous/turbulence-expert/low-re ke yes
after this you will get the LRN k-e model in the viscous panel.
Old   January 7, 2009, 02:18
Default zero equation model
sri
hai
anybody know how to impliment the zero equation model. what is zero-equation-havac thanks in advance
changing model constants in k-e turbulence model Sunil CFX 3 October 3, 2006 13:12
turbulence model greg FLUENT 3 August 26, 2006 12:07
v2-f model of turbulence abdellah FLUENT 2 February 27, 2005 01:49
HELP! TURBULENCE k-e OR k-omega TURBULENCE MODEL? Mirek Kabacinski FLUENT 5 August 24, 2003 23:31
k-w turbulence model allan Main CFD Forum 4 February 20, 2002 14:05
