Wall boundry in MRF or Moving mesh
Old   January 4, 2009, 06:54
Default Wall boundry in MRF or Moving mesh
Amir
I'm modeling a turbine ventilator which is turning in z direction. the free stream is in x direction. its a kind of turbine which you can consider like a savonius turbine with many blades.
I sketched a cylinder around the turbine ventilator as an interior. I would like to know for MRF and Moving mesh which boundary I must assign for turbine blades. I mean if I use the MRF method the wall should be moving wall with relative velocity or absolute velocity or anything else.
Generally which boundary condition must be used in my case.
best regards,
Amir.
Old   January 5, 2009, 01:46
Default Re: Wall boundry in MRF or Moving mesh
Davy
Moving wall with relative velocity of 0.
Old   January 5, 2009, 02:55
Amir
Dear Davy,
Is it applicable for both MRF and Moving mesh method?
Regards,
Amir.
Old   January 5, 2009, 19:03
Davy
this condition applies to both cases and usually you have no need to specify again since the moving wall is adjacent to a moving zone (MRF)
Stationary wall and Moving wall Sri FLUENT 1 July 29, 2008 05:33
How to make boundary layer mesh moving with wall wayne FLUENT 3 June 12, 2008 00:23
Moving Reference frame - UDF - Moving mesh modisa FLUENT 0 April 18, 2008 14:31
Deal with wall boundary with moving mesh by FVM? aiya Main CFD Forum 6 May 10, 2007 12:33
wall boundry condition fred FLUENT 0 August 19, 2004 13:10
