Dynamic mesh modeling
Old   January 3, 2009, 16:45
Default Dynamic mesh modeling
Aditya
Hi
I am trying to use Fluent for simulating flow in Axial piston pump. The mesh deforms as well as slides as the pistons reciprocate and the whole piston block rotates.
The problem is generation of negative volumes. I have hex/wedge meshes generated by cooper schemes in gambit. The grid passes the fluent and gambit checks.
I am using layering scheme for mesh updates. I also tried using very small time steps. The generation of negative volumes is near the moving boundary of the piston where the grid either collapses or stretches.
Can someone please offer any suggestions. ?
Thanks and Regards
Old   January 21, 2009, 16:44
Default Re: Dynamic mesh modeling
wesam
hello.i am student in msc degree and my research about {vortex rate sensor}i measure the output defferential pressure with the rotating velocity of sensor{dgree per sec}and i want to bulit it by gambit and solve it by fluent .mu qustion if my work need to dynamic mesh or not? thanks
gear pump modeling - dynamic mesh creating Salvatore Bocolo FLUENT 5 August 8, 2007 23:58
dynamic mesh - structured or cooper mesh Manoj Kumar FLUENT 2 November 11, 2005 02:18
dynamic mesh and sliding mesh nasser FLUENT 0 November 1, 2005 03:37
3d dynamic mesh xuzhang FLUENT 2 March 1, 2005 06:30
Help on Fluid dynamic modeling kdk Main CFD Forum 0 May 27, 2002 07:01
