modeling coduction in thin wall separating two flu
Old   December 25, 2008, 16:12
Default modeling coduction in thin wall separating two flu
mohamed ismaiel
Dear All, i need help, my case is modeling heat transfer of a thin wall of polyethylee cooled via air flow over IT'S parabolic surface, the base of this thin wall will be held at constant temperature~200 C, due to the air cooling a temperature gradient will be generated over the surface AND I NEED TO CALCULATE THE HEAT TRANSFER COEFFICIENT. I have no problem in simulating the flow field but,I can't simulate the heat transfer. moreover i can send all required data to clarify that case.
best regards, mohamed
Modeling thin perforated plates as porous media Mike FLUENT 0 August 21, 2007 05:16
Thin wall modelling in StarCCM+ Mattias Siemens 1 March 20, 2007 09:13
boundary layers on a thin wall tilman FLUENT 0 February 15, 2006 10:35
About Porous wall for thin surface. windhair1 CFX 2 October 14, 2003 06:44
Thin wall model _Fidap_membrane George FLUENT 1 May 27, 2002 02:44
