December 24, 2008, 00:44 |
Help needed Centrifugal compressor problem
Dear friends I am raghavendra doing masters in rotating machinery design and i am in my project phase now and i am studying the effect of reduction in centrifugal blade height at the exit of the impeller.
Problem impeller parameters outer diameter=406mm speed=23000 blade height at exit = 20.4 mm boundary condition pressure inlet pressure outlet solver density based viscous model k-e model realizable option Currently i am studying the effect of 20% blade height trim in fluent the problem is as i am increasing the outlet static pressure from initial 0.5 bar to 0.75 bar the total pressure across the impeller is not rising or mass flow is not changing and i noticed that i am getting high swirl number. can any one suggest me how can i fix this problem Any help is appreciated Thanks Raghavendra.M |
centrifugal compressor | Marek | CFX | 6 | December 17, 2008 12:25 |
Centrifugal Compressor BC | Tobi | Siemens | 0 | March 28, 2007 16:20 |
centrifugal compressor | siva appanna | Main CFD Forum | 5 | February 13, 2006 22:07 |
Centrifugal compressor volute | Stuman | CFX | 2 | November 29, 2005 01:25 |
centrifugal compressor modelling | Glufoureea | FLUENT | 1 | October 16, 2005 05:28 |
