unsteady solver and density method
Old   December 23, 2008, 15:25
Default unsteady solver and density method
Ellen
I'm trying to model a flow with species transport. When specifying the density of the gases, I tried two methods: using ideal-gas law or using measured density values at discrete points (by reading in a density table). Both methods worked fine with steady state simulation, however, when I changed to unsteady solver, the case with ideal-gas method still ran ok, but the case with density table had the divergence problem (Error: divergence detected in AMG solver!). All the other settings are kept the same for the two cases, so I can't figure out why the density method makes such a big difference in unsteady simulations.
Does anyone here has the answer for this? Thank you very much.
Ellen
Discrete scheme for VOF method in Large Density Ratio waynezw0618 OpenFOAM Running, Solving & CFD 0 August 11, 2008 10:46
Problem on high density ratio in Level Set method Kai Yan Main CFD Forum 10 December 25, 2007 07:12
Regarding Density based solver Eswar Main CFD Forum 2 June 6, 2007 12:00
Density based solver Eswar Main CFD Forum 2 May 29, 2007 08:29
What is Density-Based method? C-H Kuo Main CFD Forum 4 November 18, 1998 17:11
