Using MHD addon-module
Like Tree11Likes
Old   November 12, 2013, 04:09
stuart230588 is on a distinguished road
It could be that you don't have the additional license required, but the command prompt list should be:
define > models > addon-module > select option for MHD
Cheers
Stuart
Skabirian and Mit.Tech like this.
stuart230588 is offline   Reply With Quote
Old   December 3, 2014, 00:46
Dinushke
dean993 is on a distinguished road
You are getting that error, because you have to load a mesh before typing in the commands to load the MHD module.
Hope this helps,
Mit.Tech likes this.
dean993 is offline   Reply With Quote
Old   September 8, 2015, 13:17
studentuofi
infinitygee35 is on a distinguished road
hey i'm trying to activate this module as well. i type in the command properly but it says "invalid command [addon-module]"
when i type "help" and press enter it shows me the options and says that addon-module is disabled. see:
infinitygee35 is offline   Reply With Quote
Old   September 8, 2015, 13:30
studentuofi
for me fluent says "invalid command [addon-module] and when i type "help" it says that that addon-module is disabled.
what can i do now?
Old   September 8, 2015, 20:22
Dinushke
You will FIRST have to load a mesh to the Fluent, then go to enable the MHD add-on. This feature is not enabled when the mesh is not loaded in Fluent. I have tested this.
Old   September 9, 2015, 14:50
studentuofi
and how do i enable meshing? when i fire up fluent 16 i check mark the option for "meshing mode". is that correct?
if it is, i did that and when i type the command it still doesn't allow. it says "invalid command [define].
this is frustrating. need to get a flow sim done
Old   September 9, 2015, 21:18
Dinushke
No, it is not Mesh Mode. Just Start the Fluent normally (with double precision) and then click: File - Read - Mesh. Then load a mesh and once that has finished, Enter the commands.
Old   April 13, 2018, 14:46
erfan
erfan1995 is on a distinguished road
Originally Posted by Far View Post
use command addon-module and you are using addon-models. This is wrong
hi i have same problem i typed as define/models/addon-module
but it says invalid command can you help me?
erfan1995 is offline   Reply With Quote
Old   April 14, 2018, 07:21
Dinushke
Hi erfan1995,
Can you post the Text User Interface commands? Full list with the error.
Regards,
Dean
Old   April 14, 2018, 14:34
erfan
aha i had same problem but i solved it!
you should put your cursor at the end of texts in console and then press enter button once to go to next line and you will see
now type this:
you will get the point!
Old   April 14, 2018, 14:36
erfan
hi dean993 i already found the right way thank you so much!
Old   September 23, 2018, 03:59
vektor
vek123 is on a distinguished road
hello,
can you please tell me how you load the mhd module, i have fluent 19, and i read that i need to do a text command, i don't know how, i can do udfs and pretty much everything, but the text command is something i'vre never used
thanks
vek123 is offline   Reply With Quote
Old   September 23, 2018, 22:14
Dinushke
Hi Vektor,
Load Fluent with a mesh or case file. Put your cursor on the console window and hit enter. You will get a set of text. Then paste "define/models/addon-module" and hit enter. Then you will get a set of addon modules. Type "1" and hit enter to activate the model. Go to the Models tree where you will find the MHD model visible.
Originally Posted by vek123 View Post
hello,
thanks
Old   September 24, 2018, 04:45
vektor
Originally Posted by dean993 View Post
Hi Vektor,
yup, it did work, thank you so much for the tip.
Old   September 24, 2018, 08:48
erfan
you should write in console define/models/addon-module
then press enter
then press 1
it will appear in models now
Old   April 11, 2020, 11:48
Default ansys mhd problem
  #36
Manish Nath
mn1739 is on a distinguished road
Originally Posted by Payam89 View Post
First of all enhance the permeability of the particle to make sure that it's not because of permeability.
then you have to do the mhd setting at the end of the all setting in you modelI mean exactly beforethe iterration
could you email me to have a closer contact...I have a question of you project
good luck
hello sir, i am also stuck in the same problem. i tried using your technique mentioned here, but still there was no effect of magnetic field. can there be any other problem? Also, what type of wall should i use, conducting or thin?
mn1739 is offline   Reply With Quote
Old   March 23, 2022, 06:09
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
First type "define" (without inverted commas)
Then type "models"
Then type "addon-module"
A list will appear like this:
0. None
1. MHD Model
2. Fiber Model
3. Fuel Cell and Electrolysis Model
4. SOFC Model with Unresolved Electrolyte
5. Population Balance Model
6. Adjoint Solver
7. Single-Potential Battery Model
8. Dual-Potential MSMD Battery Model
9. PEM Fuel Cell Model
10. Macroscopic Particle Model
11. Reduced Order Model
Enter Module Number: [0]
Type 1 on text interface and you will be able to activate MHD model.
Far is offline   Reply With Quote
Old   June 3, 2023, 12:28
Default Unload addon module
  #38
SH
lavendar12 is on a distinguished road
I want to use another addon module, may I know how to remove the previous module? I have load module 3 and now want to load module 4. Thank you!
lavendar12 is offline   Reply With Quote
MHD Module Ashish FLUENT 2 November 18, 2017 04:40
Pemfc-addon-error message vasanth parthasarathy Main CFD Forum 2 November 25, 2013 16:55
MHD addon-module Ergys Rexhepi FLUENT 1 December 29, 2008 07:40
PEMFC addon module vasanth parthasarathy FLUENT 0 February 28, 2008 03:08
MHD Module Benny FLUENT 0 March 16, 2004 06:04
