error running fluent 64 bit in kubuntu 8.1064-bit
Old   December 20, 2008, 04:44
Default error running fluent 64 bit in kubuntu 8.1064-bit
Anastasios Georgoulas
Dear all,
I try to run fluent 6.3.26 64 bit version in kubuntu 8.10 64bit and i get the following message ageorg@ageorg-desktop:~/Fluent.Inc/bin$ ./fluent /home/ageorg/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 /home/ageorg/Fluent.Inc/fluent6.3.26/bin/fluent: 4677: domainname: not found /home/ageorg/Fluent.Inc/fluent6.3.26/cortex/lnamd64/cortex.3.7.3 -f fluent (fluent " -r6.3.26 -path/home/ageorg/Fluent.Inc") /home/ageorg/Fluent.Inc/fluent6.3.26/cortex/lnamd64/cortex.3.7.3: error while loading shared libraries: libstdc++.so.5: wrong ELF class: ELFCLASS32
Can anybody please provide me with some guidelines? What should i do?
Thanks very much in advance
Anastasios
Old   December 20, 2008, 05:32
Default Re: error running fluent 64 bit in kubuntu 8.1064-
wlh
maybe you should intall a vc++, which should be supported by 64 bit.
Old   December 20, 2008, 06:45
Thanks very much!
i will try to do that although a dont know exactly what is a vc++. I think i could find out through a google searh.
Thanks
Old   January 14, 2009, 10:55
Stefano Rolfo
I had the same problem under SUSE11.1. I solved simply installing the library libstdc++33. I don't know but may be you have the libstdc++43 that provides libstdc++.so.6. Same problem also for Gambit with the library openmotif22-libs (in opensuse is installed 2.3).
Old   January 15, 2009, 02:21
thanks for the reply i solved the problem with the same way
anyway thanks again.
Old   November 10, 2010, 04:50
isabel
isabel is on a distinguished road
Hello everybody,
When I try to execute Fluent in ubuntu 64 bits, I have the following error:
isabel@isabel:~/Escritorio$ fluent 3d
/home/isabel/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 3d
/home/isabel/Fluent.Inc/fluent6.3.26/bin/fluent: 4677: /sbin/lspci: not found
/home/isabel/Fluent.Inc/fluent6.3.26/cortex/lnx86/cortex.3.7.3 -f fluent (fluent "3d -alnx86 -r6.3.26 -path/home/isabel/Fluent.Inc")
/home/isabel/Fluent.Inc/fluent6.3.26/bin/fluent: 4715: /home/isabel/Fluent.Inc/fluent6.3.26/cortex/lnx86/cortex.3.7.3: not found
Does anybody know why?
isabel is offline   Reply With Quote
Old   November 10, 2010, 04:52
isabel
Hello everybody,
When I try to run Fluent in ubuntu 64 bits, I have the following error:
It gives error about not found cortex.3.7.3, but I really have that file. Does anybody know what is happening?
Old   November 10, 2010, 10:35
Default Fedora and SuSE
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
When it comes to Linux, Fluent can only be run on either Red Hat, including Fedora or SuSE.
vinerm is offline   Reply With Quote
Old   November 10, 2010, 13:26
isabel
Hello vinerm,
Sorry but I do not know what Red Hat, Fedora and SuSE means.I will tell you the details of my problem:
I succesfully installed Fluent in my 32 bits ubuntu. When I execute Fluent I obtain this message:
/isabel@isabel-desktop:~/OpenFOAM/isabel-1.5/applications/solvers/mono52$ fluent
/home/isabel/Fluent.Inc/fluent6.3.26/bin/fluent: 4677: domainname: not found
/home/isabel/Fluent.Inc/fluent6.3.26/cortex/lnx86/cortex.3.7.3 -f fluent (fluent " -alnx86 -r6.3.26 -path/home/isabel/Fluent.Inc")
And Fluent runs Ok.
Recently I changed to 64 bits ubuntu, I installed Fluent but when I try to execute it gives the following error:
isabel@isabel:~$ fluent
The strange thing is that the file cortex.3.7.3 does exist and I do have it in "/home/isabel/Fluent.Inc/fluent6.3.26/cortex/lnx86/cortex.3.7.3"
Old   November 11, 2010, 10:14
vinerm's Avatar
Vinerm
Is Fluent you installed on 64 bit machine a 64 bit version? That could be the issue. We use 64 bit machines and in their path, x86 is always replaced by x86_64.
Old   November 11, 2010, 10:58
isabel
This Fluent works Ok in linux 32 bits version, so I think it is not a 64 bits version.
Can I do something to install it in the 64 bits version of linux?
Old   February 9, 2011, 07:21
Girolamo
lift86 is on a distinguished road
I installed fluent but when I launch it gives me the following errors. I tried to install the library libstdc + +33, butcan not find it . What can I do?
/home/gir/Scrivania/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26
/home/gir/Scrivania/Fluent.Inc/fluent6.3.26/bin/fluent: 4677: /sbin/lspci: not found
/home/gir/Scrivania/Fluent.Inc/fluent6.3.26/cortex/lnx86/cortex.3.7.3 -f fluent (fluent " -alnx86 -r6.3.26 -path/home/gir/Scrivania/Fluent.Inc")
/home/gir/Scrivania/Fluent.Inc/fluent6.3.26/bin/fluent: 4715: /home/gir/Scrivania/Fluent.Inc/fluent6.3.26/cortex/lnx86/cortex.3.7.3: not found
lift86 is offline   Reply With Quote
Old   February 10, 2011, 04:12
isabel
Hello lift86,
What version of Fluent are you installing, 32 bits or 64 bits?
And what version is your linux, 32 bits or 64 bits?
Old   February 10, 2011, 07:56
Girolamo
HEllo Isabel,
fluent is 64 bits and my prcessor is 64 bits
Old   February 10, 2011, 08:45
DoHander is on a distinguished road
@lift86
Have you searched the Debian repositories ? They have a lot of stuff (binary compaible with Ubuntu), you may have a chance to find your libstdc++ library version.
Try to use the Ubuntu IRC chat on freenode, there are a lot of smart guys there, just ask about finding the desired library and where to find it.
Do
DoHander is offline   Reply With Quote
Old   February 10, 2011, 09:39
isabel
Ok, Dohander. But probably my problem is because I am trying to install a 32 bits fluent into a 64 bits ubuntu.
Old   February 10, 2011, 11:04
@isabel
Sorry my message was for lift86, my bad that I didn't mentioned this .
In your case, yes, this is the problem - however on a 64 bits machine you can install, if you want, a 32 bits Linux. You can create a separate partition on which you can install Ubuntu 32 bits and your 32 bits Fluent version.
The ideal solution will be to install Fluent 64 bits on your current machine.
Do
Old   February 17, 2011, 13:57
isabel
Hello everybody,
I have installed Fluent 64 bits in my ubuntu 64 bits, but now I have the following problem:
/home/isabel/Fluent.Inc/fluent6.3.26/cortex/lnamd64/cortex.3.7.3 -f fluent (fluent " -alnamd64 -r6.3.26 -path/home/isabel/Fluent.Inc")
/home/isabel/Fluent.Inc/fluent6.3.26/cortex/lnamd64/cortex.3.7.3: error while loading shared libraries: libstdc++.so.5: wrong ELF class: ELFCLASS32
So I have typed the following command:
sudo apt-get install libstdc++5
And I had the error It could not be found the packet libstdc++5
If I type locate libstdc++.so, I have the following:
/home/isabel/Fluent.Inc/fluent6.3.26/lnamd64/syslib/libstdc++.so.5
/home/isabel/Fluent.Inc/fluent6.3.26/lnamd64/syslib/libstdc++.so.5.0.3
/home/isabel/OpenFOAM/OpenFOAM-1.7.1/lib/libstdc++.so.6
/usr/lib/libstdc++.so.6
/usr/lib/libstdc++.so.6.0.13
/usr/lib/gcc/x86_64-linux-gnu/4.1/libstdc++.so
/usr/lib/gcc/x86_64-linux-gnu/4.4/libstdc++.so
Is the problem that I should have the library in /usr/lib/libstdc++.so.5 instead libstdc++.so.6?
Old   March 9, 2011, 04:54
isabel
If I type “ldd cortex.3.7.3” in my Fluent 32 bits with Ubuntu 32 bits I obtain this information:
isabel@isabel-desktop:~/Fluent.Inc/fluent6.3.26/cortex/lnx86$ ldd cortex.3.7.3
linux-gate.so.1 => (0xb7715000)
libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0xb76e4000)
libhoops1127.so => not found
libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0xb76df000)
libXt.so.6 => /usr/lib/libXt.so.6 (0xb768c000)
libXext.so.6 => /usr/lib/libXext.so.6 (0xb767c000)
libX11.so.6 => /usr/lib/libX11.so.6 (0xb758d000)
libstdc++.so.5 => not found
libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb7566000)
libgcc_s.so.1 => /home/isabel/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/lib/libgcc_s.so.1 (0xb7559000)
libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb73f6000)
/lib/ld-linux.so.2 (0xb7716000)
libSM.so.6 => /usr/lib/libSM.so.6 (0xb73ed000)
libXau.so.6 => /usr/lib/libXau.so.6 (0xb73e8000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0xb73ce000)
libICE.so.6 => /usr/lib/libICE.so.6 (0xb73b6000)
libuuid.so.1 => /lib/libuuid.so.1 (0xb73b1000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0xb73ac000)
As you can see, the library “libstdc++.so.5” is not found, but Fluent runs Ok.
Nevertheless, in my Fluent 64 bits in Ubuntu 64 bits, Fluent do not run without that library.
Does anybody know what I can do?
Old   July 5, 2011, 16:08
Smile answer
  #20
vlg
villager is on a distinguished road
Yes, maybe I'll be able to help you. On the other hand, I manage with it on Ubuntu 10.10 (Maverick). I've just needed to work on Fluent+Ubuntu myself, and looking for solution of this problem, I've met this page.
First, add to yours ~/.bashrc following lines:
export FLUENT_ARCH=lnamd64
export FLUENT_INC=~/Fluent/Fluent.Inc
export FLUENT_LICENSE_FILE=$FLUENT_INC/license/license.dat
export PATH=$FLUENT_INC/bin:$PATH
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/villager/Fluent/Fluent.Inc/fluent6.3.26/lnamd64/syslib:/home/villager/Fluent/Fluent.Inc/lib3.0/lnamd64
Note, that I had my Fluent.Inc in /home/villager/Fluent. You have it in some other dir.
Second, I installed following packages:
gcc-3.3-base
cpp-3.3
gcc-3.3
libstdc++5_3.3.6-15
as it was recommended here for Ubuntu. I suppose, such packages can be found for Xubuntu too.
It's a key step. Fluent doesn't want to find libstdc++.so.5,
libdl.so.2 => /lib/libdl.so.2 (0x00007facb2ec9000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x00007facb2ca5000)
libXt.so.6 => /usr/lib/libXt.so.6 (0x00007facb2a3f000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x00007facb282d000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x00007facb24f7000)
though this lib is contained in /usr/lib (not? then
sudo apt-get install ia32-libs
It should be also noted, Fluent 64-bit needs libstdc++.so.5 that is 32-bit library, as well as standard x86_64 libraries.
Third,
sudo ldconfig -v|grep libstdc++
At last,
ldd -d /home/villager/Fluent/Fluent.Inc/fluent6.3.26/cortex/lnamd64/cortex.3.7.3
All packages should be found.
This way I managed to get through all errors, but the evening was lost. Hope, you will too.
villager is offline   Reply With Quote
[Netgen] Installation on Kubuntu 710 sega OpenFOAM Meshing & Mesh Conversion 0 September 20, 2008 12:04
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
FIDAP RUNNING ERROR "ERROR-DIR-NOT-EMPTY=145" BAOYU FLUENT 0 January 26, 2006 19:32
DPM running error! x.p.lee FLUENT 0 July 3, 2003 06:44
error while running UDF murthy FLUENT 1 October 22, 2001 06:02
