how to simulate a granule falling down in water
Old   December 17, 2008, 08:47
Default how to simulate a granule falling down in water
poiu
hellow:
I want to use FLUNT to simulate the progress of a granule falling down from water.But i have no idea how to set the model,can you give me a help? Should i use the moving mesh? If the granule is a porous one,how to set the profile of it in FLUENT?
Thank you.
Old   December 17, 2008, 21:45
Default Re: how to simulate a granule falling down in wate
Yasser Selima
I think you don't have to use moving mesh. you should use Discrete phase model (DPM) and let your granule enter from the top.
Old   December 17, 2008, 22:22
poiu
Thanks for your answer,but i have some question. The granule is not a small particle,it's diameter is about 2 mm and it is a porous one,so if i use the DPM,how to set my granule?
Old   December 18, 2008, 05:28
Rami
The "Solving a 2D Box Falling into Water" tutorial might help.
Go to http://www.fluentusers.com/fluent/tr...ials/index.htm (need no subscribe) and scroll down to this tutorial.
I must say I myself am stuck with application of the dynamic mesh in a similar (but somewhat more complicated) problem of few solids sinking and floating in a fluid. Support from the local agent and Fluent support is delayed for a long time, so I really can't say for sure how good the dynamic mesh is (but can say for sure their support level is lousy). However, since you need to model a single solid - you may be more successful than me...
Simulation of a free falling wedge into water 2D nico765 OpenFOAM Running, Solving & CFD 3 January 11, 2009 03:47
How to simulate water hammer in pipeline? Jass FLUENT 2 December 11, 2008 15:37
How to simulate the water hammer pressure. arwang FLUENT 0 March 12, 2007 08:07
Use smoke density to simulate water Wei-zhi Liao Main CFD Forum 0 February 13, 2006 04:06
falling of ball in water nabeel mohsin FLUENT 2 November 26, 2004 06:50
