how to define rotating scheme
Old   December 15, 2008, 09:44
Default how to define rotating scheme
Amir
Hi, I'm simulating a rotation of a wind driven turbine ventilator which contains two main parts. one is a rotating part consist of some vertical blades and a dome, second part is a stationary cylinder which the rotating part is placed on it. these two parts are attached to each other.
my first question is; in which range the Y+ should be for the Reynolds Number around 1000000?
my second question is; which method is appropriate for this case? Moving Reference Frame, Sliding Mesh or Moving Mesh?
I appreciate any help.
Regards.
Old   December 19, 2008, 04:05
Default Re: how to define rotating scheme
Anastasios
I think it is easier if you set the flow field and the cylinder rotating and leave the blades stationary. This is the same as the case that the blades rotating and all the other part remain stationary.
Hence, you should use moving reference frame (rotating) for the flowfield and the cylinder from fluent.
I hope this is clear.
best luck
Anastasios
Old   December 19, 2008, 09:52
Amir
I put the blades inside two cylinders to be able to generate proper mesh. The inner cylinder has a diameter same as turbine base. should I rotate these two cylinder which I split already separately, or I must specify them as one flow region?
when I Choose these two cylinder as one flow region the inner cylinder face acts not like an interior.
Regards
Amir
Old   December 21, 2008, 13:18
Anastasios
Can you please give me a schematic of your geometry in order to better understand your problem?
Anastasios
Old   December 22, 2008, 17:16
Amir
Hi
Thank you so much
can you give me your e-mail address then I'll be able to send you the related data and schematic of the geometry?
Best regards. Amir
Old   December 22, 2008, 17:32
Anastasios
dear Amir,
My mail address is the following,
ageorg@civil.duth.gr
IcoDyMFoam how to define more than one rotating regions naoko_oyama OpenFOAM Running, Solving & CFD 0 November 14, 2008 09:25
define grading scheme John Deas FLUENT 0 February 6, 2008 11:18
Counter rotating wall for rotating domain melvin CFX 0 February 4, 2008 05:51
Difference b/t rotating wall and rotating domain? Juno Kim CFX 2 February 20, 2007 21:08
How to use UDF to define a rotating wing lyf FLUENT 3 April 7, 2004 05:31
