Incident Radiation
Old   December 15, 2008, 08:40
Default Incident Radiation
yilmaz
Hello all, i have a simple question i.e What is the difference between the incident Radiation under Radiation field variable and Surface incident radiation under wall fluxes? Also i need help on how to calculate the surface incident radiation for each band seperately. Fluent doesn't give the possibility to see these values on a band basis.
Thanks in advance
Old   December 16, 2008, 09:05
Default Re: Incident Radiation
Rami
I am quite new to Fluent, so I cannot answer your last question. It is simple in principle, but I don't know if it is implemented in Fluent. Hopefully someone else will advise.
The first addresses radiative transport in general, so I will try to clarify.
Incident radiation is defined as the integral of the intensity at a point over the whole directional sphere (solid angles between 0 and 4Pi). The surface incident sphere is the same, but now only the hemisphere pointing from the surface into the domain (from which radiation is impinging on this surface) is relevant, and therefore the integral is carried on this hemisphere only.
Old   December 6, 2019, 16:37
Junjun Guo
Junjun Guo is on a distinguished road
Originally Posted by Rami
;155435
There is also a value of incident radiation on the wall, but it different from the surface incident radiation. Do you know why?
Junjun Guo is offline   Reply With Quote
Old   April 6, 2023, 06:26
Tol
altinoluk_t is on a distinguished road
"Incident radiation is defined as the integral of the intensity at a point over the whole directional sphere (solid angles between 0 and 4Pi). The surface incident sphere is the same, but now only the hemisphere pointing from the surface into the domain (from which radiation is impinging on this surface) is relevant, and therefore the integral is carried on this hemisphere only."
The statement I guess quite correct. Just multiply your Surface Incident Radiation value by 4 by using Expression Editor, and compare it with the Incident Radiation under Radiation. I saw these two were the same. That means, Surface incident radiation integrates the intensity over one pi, whereas Incident radiation does it for 4 pi.
altinoluk_t is offline   Reply With Quote
radiation temperature ,G(the incident radiation) ymg FLUENT 0 October 16, 2008 09:57
how to reference incident radiation when using DO ding FLUENT 2 May 16, 2007 22:39
DO Surface incident radiation Problem Thomas FLUENT 0 March 18, 2005 04:55
Macro/Cell-variable for incident radiation ? Vishnu FLUENT 0 April 7, 2001 00:29
Fluent incident radiation problem Michael Schwarz Main CFD Forum 0 October 21, 1999 06:56
