When to use double precision?
Old   December 11, 2008, 15:09
Default When to use double precision?
Paul
When is it beneficial to use the double precision solver for fluent? I can't seem to find a real answer to this anywhere.
Thanks.
Old   December 11, 2008, 15:25
Default Re: When to use double precision?
Denis
The use of double precision in Fluent is basically the same than for any other numerical code. It is needed everytime you need to capture a small variation of a quantity that can vary by large amounts. For instance if you have a very stretched mesh, with some cells dimensions beeing way higher than others, double precision will be helpful.
Old   December 11, 2008, 16:15
Paul
If I have models which are giving me many incompletes on the DPM, would double precision help eliminate them?
Old   December 11, 2008, 17:57
Denis
Most likely not, incomplete in DPM means that you are not having enough integration steps on your particles, or that the step are too small.
double precision cfx pat CFX 5 November 11, 2008 07:45
OpenFOAM Double precision vs Single Precision alexandrepereira OpenFOAM Running, Solving & CFD 1 June 11, 2008 15:30
When to use double precision Mark Render Main CFD Forum 10 January 21, 2008 13:16
UDF & Double precision; Please help?? Asghari FLUENT 0 January 31, 2007 14:14
Double Precision? Novak Elliott CFX 1 June 6, 2003 02:45
