December 10, 2008, 16:32 |
Calculation of Drag Coefficient manually
In a given 2-D geometry, which area does fluent considers for the calculation of Drag Coefficient? I am solving for the drag of an ellipse. Fluent gives the value of Drag Coefficient directly. But how do we know the area considered by fluent?
December 10, 2008, 21:35 |
Re: Calculation of Drag Coefficient manually
The area is simply the cross sectional area of a sphere, pi*r^2
December 11, 2008, 00:48 |
Projected area is used in finding lift and drag coeffiecient. For example, you can give the diameter of cylinder when you are interested in flow over cylinder.
December 17, 2008, 16:20 |
I was trying to mach the coeffient of drag value calculated by fluent with my mannual calculation, but the values were different. But Later I found that fluent takes some default vale of Area and other parameters. It does not consider the Area in our geometry.
December 13, 2012, 16:31 |
area problem
Chaudhary
Rep Power: 14 |
i want to calculate area of circles which would be used in ansys fluent ....
it is 2d heat exchanger and i have problem how to calculate area of circle in front of flow or which area i have to put in reference value .. i have confusion whether i have to use area of 2 or 4 circles ??? kindly tell me how to calculate this area or which area i have to put in reference value ??? i have attached the jpeg. file of structure to further explain it ? waiting for answer...i will be very thankful to you. what Reference values should I used in fluent to find the area as defaults values are 1 for area,depth and length. Area=? Depth=? |
Fluent Good Lift coefficient BAD drag coefficient | Rif | Main CFD Forum | 4 | March 9, 2010 11:52 |
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re | lin | OpenFOAM Running, Solving & CFD | 3 | April 16, 2009 11:50 |
low drag coefficient | Jason | FLUENT | 3 | August 14, 2008 01:53 |
Is the drag coefficient right? | mimibenben | FLUENT | 3 | July 13, 2006 23:14 |
Coefficient of drag | sam | Siemens | 4 | May 26, 2005 06:47 |
