Erros in Fluent, access Violation
Old   December 9, 2008, 10:01
Default Erros in Fluent, access Violation
sk
Hai
I am working ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~ 1. For my problem I can compile my udf successfully. When I try to iterate, I receive the following error message.
Error: FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~ 1. When I try to run one of the tutorial in the Fluent. While compiling the udf, I get this problem. My pc is 64 bit machine and I am working with Windows.
c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2143: syntax error : missing '{' before ':'
c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2059: syntax error : ':'
c:\fluent.inc\fluent6.3.26\cortex\src\dll.h(58) : error C2061: syntax error : identifier 'CX_DLL_GetProc'
c:\fluent.inc\fluent6.3.26\cortex\src\dll.h(58) : error C2059: syntax error : ';'
c:\fluent.inc\fluent6.3.26\cortex\src\dll.h(58) : error C2059: syntax error : 'type'
When I try to search over the forum I cannot find any consistent solution for both the problems. ? Can someone help me out.
Thanks.
Sk. --
Old   December 10, 2008, 03:17
Default Re: Erros in Fluent, access Violation
naga
hi,
have installed visual studio in ur PC for compiling...Try that.. if u have visual studio and still some problem exists pls send me that UDF
Old   December 10, 2008, 06:27
sk
Hi Naga,
I have rectified error no. 1. Thats becos I was not properly hooking the udf.
But still error 2 is pending.
But now I have problems with Floating point error . Any pointer for that.
Thanks for your reply.
Access violation error with Fluent 6.2 Prasad Dudhgaonkar FLUENT 4 November 27, 2013 14:06
access violation co2 FLUENT 5 November 7, 2010 11:48
Access Violation Help!!!!!! thuy FLUENT 0 March 5, 2008 09:26
Access violation - Help please AlwaysLearning FLUENT 3 August 22, 2006 13:21
access violation R.B.M FLUENT 3 July 11, 2002 06:07
