How to set up more than 270 planes in Fluent?
Old   December 9, 2008, 09:50
Default How to set up more than 270 planes in Fluent?
Julian K.
Hallo,
for analysing purposes, I need to create more than 270 bounded planes in the post processing (Surface -> Plane...). Since I do not want to spend about a week for typing the coordinates I am looking for an alternate, faster way.
I have all coordinates for the planes in an Excel-file. So, it would be best, if I could just write a code and copy&paste the coordinates.
I thought, that I could maybe modify the case/data file of my simulation and insert the planes there. However, I was not able to find the passage, where the planes are defined.
Does anyone has an idea how to accelerate the creation of the planes?
Good bye,
Julian
Old   December 10, 2008, 07:11
Default Re: How to set up more than 270 planes in Fluent?
Julian K.
So I found a solution.
Using an Excel macro I created a journal file for Fluent containing all the coordinates. Now, Fluent does all the work for me, automatically...
Topic Closed
Old   July 16, 2010, 13:29
Yarzar
ATOTA is on a distinguished road
Could you tell me exactly how the journal file works ? I am in a similar situation where I need to input over 200 surface points instead of surface planes.
Thank you very much.
ATOTA is offline   Reply With Quote
Old   January 5, 2011, 01:04
Exclamation
gi12 is on a distinguished road
Hi all
what in this post is very helpful. would you kindly give explanation how dose this work with lines and planes?
gi12 is offline   Reply With Quote
mixing planes sulilatu FLUENT 0 December 5, 2006 04:34
Creating Planes Steve FLUENT 1 April 6, 2004 15:43
Creating complex planes Steve FLUENT 3 April 6, 2004 13:55
Mixing planes ramesh FLUENT 0 July 30, 2002 03:33
Defining cutting planes Daniela FLUENT 3 December 19, 2000 09:13
