November 24, 2008, 08:30 |
CFD of Model Aircraft
I need to analyze the flow over a model aircraft. Which CAD package would be better for this - CATIA or UGNX? I also want to know if I should model the aircraft as a solid body for the analysis or could i model it as an assembly(inclusing all components) and still perform the analysis? |
November 25, 2008, 22:37 |
Re: CFD of Model Aircraft
CATIA and UGNX are available.I used UGNX, but CATIA's model could be imported into gambit directly. So I recommend you use CATIA. it depends on your data through the simulation. Sometimes you may simplify your model such as a body. by the way, zone for calculation is a box that subtract the aircraft model.
November 26, 2008, 02:36 |
Thanks for your reply. Do you think GAMBIT s good enough a mesh tool for me to mesh my aircraft?
Thanks! |
November 26, 2008, 04:06 |
you can see the GAMBIT Tutorial Guide that have a case called "AIRPLANE GEOMETRY". I think this is usefull to you. but if you want to calculate the viscous fluid, you may use the Tgrid tools, and it can generate prism mesh to satisfy boundary requirement.
Good luck, xinboy! |
December 2, 2008, 00:13 |
I am getting an error while meshing in GAMBIT (skewness). Would it be possible for you to send me that GAMBIT tutorial on 'Airplane Geometry'? Thanks! |
December 4, 2008, 04:46 |
I need to computation drag and lift of 2d aerofoil
December 4, 2008, 04:47 |
I need to computation drag and lift of 2d aerofoil(code matlab)
December 8, 2008, 04:33 |
sorry,I haven't log in this forum for a long time. have you had the help document! I have it,but it's very large. So what way did I can send you by?
December 8, 2008, 05:38 |
#9 |
Is it possbile for you mail it to me? Or if you send me the link to download it also its fine. If the whole file is not possible can you atleast mail me the portion on aircraft geometry.. Thanks a lot! |
December 8, 2008, 06:53 |
#10 |
OK,I'll send the portion to you! please wait!
CFD Analysis of Model Aircraft | Sashankh | Main CFD Forum | 8 | November 22, 2013 15:02 |
CFD Analysis of Model Aircraft | Sashankh | FLUENT | 0 | December 1, 2008 23:49 |
Looking for an aircraft wing model........ | mimi | FLUENT | 4 | May 28, 2007 05:36 |
model for an aircraft propeller | Tim Lammering | FLUENT | 0 | April 10, 2006 07:58 |
Aircraft model? | Jason | FLUENT | 0 | December 7, 2004 14:59 |
