udf compile in parallel system
Old   November 22, 2008, 04:34
Default udf compile in parallel system
tahereh
hi all friends I have a big problem in compiling my udf in parallel system. MY project is with dynamic mesh and i have to use DEFINE-CG-MOTION. in serial systems at first I compile the udf fromuser-define function compile) then I build the udf and at last I run nmake in visual c++ and load the udf so in this way i don't have any problem. but in parallel system when i do these the udf wouldn't be loaded. please help me to overcome this problem. thanks so much.
Old   December 9, 2008, 10:48
Default Re: udf compile in parallel system
MaxG
I have the same problem: trying to compile a UDF that so far has worked correctly in serial mode (on SUN workstation), I cannot get the UDF to compile on parallel Fluent (lnx86_glibc22 architecture). By doing the compilation steps manually (TUI), i get an error in the makelog file that says that the default flags for cc compiler are not recognized; by manually resetting cc flags, i get error messages in the FLuent header files (threads.h, etc.).
problem with parallel system tahere FLUENT 2 December 27, 2008 19:44
Parallel computer system for FLUENT analysis Jane FLUENT 4 December 4, 2008 02:26
Fastest parallel solver for tridiagonal system Arpiruk Main CFD Forum 16 August 28, 2007 06:14
UDF COMPILE Miguel Olvera FLUENT 4 March 18, 2007 09:07
Linear system - parallel Dino Main CFD Forum 0 September 24, 2003 10:35
