Internal Flow BCs for Compressible inlet flow |
I'm having issues modeling subsonic flow through a serpentine diffuser within fluent. I am currently using a pressure inlet and pressure outlet condition. The pressure inlet specifies a total gage pressure corresponding to the freestream Mach number (0.8) I'm interested in. The pressure outlet is set at a gage pressure of 0. The computational domain extends past the exit plane so that the BC does not interfere with the solution. The issue I'm having is that as the solver iterates, the Mach number increases at the entrance to supersonic flow (approximately Mach 1.36). I've tried to extend the domain even further at the exit however this did not help. Any ideas would be greatly appreciated! Katie |
Try starting the run using a less aggressive inlet condition and ramp it up as the solution progresses.
Syavash Asgari
Rep Power: 18 ![]() |
Hi katie,
I am interested in your problem because I've got a similar one. Could you finally find a solution for resolving the Unexpected mach increasing at the inlet? tnx |
Internal error in compressible flow be density | Mirek | FLUENT | 0 | August 20, 2008 08:59 |
Mass flow inlet compressible flow | richard | FLUENT | 2 | June 1, 2008 11:44 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
Compressible flow with inlet velocity Ma%23601 | klaus | OpenFOAM Running, Solving & CFD | 2 | July 3, 2005 15:43 |
External Flow-compressible flow solver-lift/drag | Tom Brown | Main CFD Forum | 7 | December 29, 2000 13:41 |
