Flow Over Flat Plate
Old   November 11, 2008, 23:44
Default Flow Over Flat Plate
Lance
I have been trying to model flow over a flat plate for a number of weeks now. It seems like an easy problem, but I cannot get the lift and drag coefficients to coincide with theoretical values. I am modeling a vertical axis wind turbine blade with a chord length of 4 inches and width of 16 inches. I am running the k-e turbulence model with enhanced wall treatment. My Y+ value averages around .5 and I am running a Reynolds number of 84,000. The plate is at a 45 degree angle. Current runs produce a Cd and Cl of 1.5 when the actual value is closer to 0.9.
Is there something wrong with this setup? Also how am I to know if there are shedding vortices in the model I am running? I have run unsteady simulations but have seen no indications of shedding. Any help would be appreciated.
Old   November 13, 2008, 23:20
Default Re: Flow Over Flat Plate
jacob
it is impossible, your screwed(this is jacob)
Flow over a flat plate: BCs Paolo Lampitella FLUENT 5 October 24, 2012 15:54
flow over an infinite flat plate Vijay CFX 0 April 7, 2008 06:01
supersonic flow over a flat plate Vishwajeet Main CFD Forum 1 April 15, 2007 23:00
FLOW OVER FLAT-PLATE *again* Yogesh Talekar Main CFD Forum 10 September 27, 1999 13:08
Flow over FLAT-PLATE Yogesh Talekar Main CFD Forum 4 September 21, 1999 07:17
