Plane, which traps particules but don't alter flow
Old   November 10, 2008, 11:39
Default Plane, which traps particules but don't alter flow
Julian K.
Hallo,
I would like to create a plane using FLUENT, with the following properties:
- it should trap particules, which were released before
- it should not influence the flow in any way
Can this be realised? Maybe with a UDF?
Thanks,
Julian
Old   November 10, 2008, 12:32
Default Re: Plane, which traps particules but don't alter
Julian K.
I forgot to mention, that the particles, which touch the plane should be counted.
If possible, the particles should disappear after they touched the plane.
The plane itself is placed somewhere in the domain.
Old   November 10, 2008, 19:58
aas
hello,
I know of a way but it would only be useful for post-processing. you can use a DEFINE_DPM_OUTPUT macro and take a discrete phase sample only selecting the plane you defined. in the UDF, you can use a counter variable to increment each time the sample is taken at the plane. to trap the particles, you can use the following statement:
p->stream_index=-1;
Using UDF to alter particle size Tumppi Fluent UDF and Scheme Programming 7 February 28, 2019 09:27
Alter turbulence parameters newbee OpenFOAM Running, Solving & CFD 7 August 29, 2006 03:31
Flotation of gasoil particules in water Alec FLUENT 5 June 20, 2006 05:51
How to create plane coutte flow by using LBM? TSYen Main CFD Forum 0 September 9, 2004 06:24
Traps John C. Chien Main CFD Forum 29 September 29, 2001 16:31
