UDF COMPILATION...
Old   November 8, 2008, 12:21
Default UDF COMPILATION...
venkatesh4386@gmail.com
when i try to compile my udf in fluent i get the error message as
make[1]: Entering directory `/home/mas/07/asetvk/Desktop/project/libudf/lnamd64/3d' make[1]: Warning: File `makefile' has modification time 1.4e+03 s in the future
make[3]: warning: Clock skew detected. Your build may be incomplete.
i am using linux 64 bit system.... can u sort out this problem
thanku,
venkat
Old   November 8, 2008, 20:28
Default Re: UDF COMPILATION...
Frederick
I am not sure there is a problem. I get this message all of the time and my subroutines still execute as intended.
Old   December 1, 2008, 09:58
Michael
check if you have set up VC,or set envionment variables
UDF COMPILATION... venkatesh4386@gmail.com FLOW-3D 0 November 8, 2008 12:22
Compilation alessio Siemens 1 September 18, 2008 04:32
UDF COMPILATION T.Hariharanath FLUENT 2 July 25, 2005 12:47
UDF compilation: need VC++? Biga FLUENT 3 November 6, 2004 14:34
udf compilation jy FLUENT 0 August 10, 2000 10:39
