compressible and incompressible flow
Old   November 8, 2008, 01:39
Default compressible and incompressible flow
chinababu
i am trying to solve one problem having both compressible (air-ideal gas) and incompressible (water) fluids and the solution is not converging but when we have taken both the fluids (air &water) as incompressible fluids, the solution is converging. Can you tell what the problem in giving conditions was and how to handle the problem if we are having compressible and incompressible fluids using simultaneously?
Old   November 8, 2008, 05:52
Default Re: compressible and incompressible flow
mahi
You can try a density based solver. I think you are using a pressure based solver
Old   November 9, 2008, 01:36
peterliu
what do your boundary conditions for your outlet ? try to use pressure out-let.
Old   November 11, 2008, 13:16
Amod@Siemens
So long MAch number for air (the compressible) media is < 0.3, you can always treat it Incompressible without loss of acccuracy!
What phenomena (application) are you trying to solve!
Old   November 13, 2008, 06:56
mahi
Dude, try a pressure based coupled solver. It might work in your case. Give air as compressible and water as incompressible phases
Incompressible and compressible flow. Confused student. Main CFD Forum 27 March 18, 2017 13:25
NS-incompressible and compressible flow solvers ag Main CFD Forum 2 September 27, 2005 07:18
using compressible options in incompressible flow Kali Charan Nayak CFX 2 August 10, 2005 01:42
Incompressible and compressible flow. John. Main CFD Forum 1 December 15, 2004 12:29
Incompressible and compressible flow boris FLUENT 0 February 20, 2002 04:08
