high pressure simulation
Old   November 7, 2008, 02:30
Default high pressure simulation
mahi
I am doing a flow simulation inside an engine. The domain is the space between the piston and the cylinder. It is a 2 phase flow with air and oil, with a time varying pressure and temperature at the inlet and ambient conditions at the outlet, with one outer wall moving(sinusoidal profile). The pressure can be as high as 50 bar at some point in time. The mesh has been completed and the simulation is running fine with simple flow conditions. Do I have to make any changes to the supersonic pressure condition at the inlet when I test with high pressure? Right now I am getting floating point error at high inlet pressure.
simulation of airfoil at high AOA hsnu84053 FLUENT 0 January 26, 2007 22:34
high pressure gas release ahourri FLUENT 0 November 17, 2005 00:45
MRF simulation : continuity residual high as 0.4 guru FLUENT 2 February 7, 2005 10:33
Injection at high pressure florian(munich) FLUENT 0 October 28, 2004 14:59
FIDAP-simulation with high viscotities Wolfgang Korte FLUENT 2 November 2, 2000 14:14
