UDF temperature variation
Old   October 31, 2008, 10:48
Default UDF temperature variation
Alex E-H
Hi. I am new to using UDFs and have read through the help file. I am attempting to create an inlet velocity whose temperature varies sinusoidally every 24 hours. My udf file is given below:
#include "udf.h"
DEFINE_PROFILE(test,thread,position)
{ real x[ND_ND]; /* this will hold the position vector */
real y;
face_t f;
begin_f_loop(f,thread)
F_CENTROID(x,f,thread);
y=x[0];
F_PROFILE(f, thread, position) = 10.*sin(t*(pi/720.)) */ here stands the profile function as a function of time /*
end_f_loop(f,thread)
I am receiving an error message when interpreting in fluent:
"cpp -IT:\XP\Fluent.Inc\fluent6.2.16/src -IT:\XP\Fluent.Inc\fluent6.2.16/cortex/src -IT:\XP\Fluent.Inc\fluent6.2.16/client/src -IT:\XP\Fluent.Inc\fluent6.2.16/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" U:\4th yr\FYP\2nd\Unsteady\udftempprofile.c Error: U:\4th yr\FYP\2nd\Unsteady\udftempprofile.c: line 1: parse error."
Any help is much appreciated
Old   November 7, 2008, 09:04
Default Re: UDF temperature variation
e0125583
looks like a syntax error. check if the file-format of you c-file is unix (not DOS) or try to compile the udf instead of interpreting it.
Old   February 19, 2017, 09:19
Default Bulk Temperature
Zohud Mohammed
Zohud is on a distinguished road
Dear all; i am studying the heat transfer of nanorefrigerant in horizontal tube under heat flux constant; but i need a method for calculate the bulk temperature of fluid for every points on axes x. I trying write udf but there an error
UDF for calculate the bulk temperature
#include "udf.h"
DEFINE_Tb(Tbulk,thread,temp)
real Tb;
real y[ND_ND];
real u=f_U(f,t)
real temp = F_T(face, thread); /* get face temperature */
face_t f;
begin_f_loop(face,thread) /* loops over all faces in the thread passed
in the DEFINE macro argument */
Tb = SUM u*temp*y / SUM u*y;
end_f_loop(face,thread)
Please help me
Zohud is offline   Reply With Quote
Old   February 19, 2017, 15:55
Jad nakhl
jadnakhl is on a distinguished road
Hello sorry disturbing but i posted earlier and no one answered.
If anyone can tell me how should i draw an expanding circular pipe without getting an error in the setup if want to make a line in the drawing as centerline and by putting the problem type as axisymmetric.
jadnakhl is offline   Reply With Quote
UDF temperature variation Alex E-H FLUENT 2 November 5, 2008 10:18
Pressure temperature variation Dev CFX 0 June 22, 2007 00:01
Viscosity variation with temperature for gases- Kedar Main CFD Forum 3 October 24, 2005 07:43
variation of surface tension with temperature Markus FLUENT 1 July 17, 2002 21:23
Property variation with temperature G.Balakrishnan FLUENT 1 December 16, 2000 07:51
