Combustion Model
Old   October 30, 2008, 02:46
Default Combustion Model
Rachel
I am running a case in which the methane and air are introduced into a burner seperately. The result using eddy dissipation model looks good, however, the results using either finite rate/eddy dissipation or EDC are totally wrong. What's the matter with it?
Thanks a lot.
Old   November 1, 2008, 13:43
Default Re: Combustion Model
jesse
difference between pre-mixed and non-premixed flame model?
Old   November 2, 2008, 13:14
Rachel
Hi, Jesse Actually, the Non-premixed model available in FLUENT could give a sound results. I just wander why the finite-rate/eddy dissipation and EDC do not work?
Old   November 11, 2008, 21:29
Carl
May I know more detailed about the case that you are simulating? I'm currently looking at EDC model as well. Maybe we can discuss about it.
combustion model in premixed combustion chamber wuyu FLUENT 9 February 16, 2018 11:40
Sawdust Combustion-Non-premixed Combustion Model Jessy FLUENT 1 June 19, 2007 11:59
Combustion model MANOJ KUMAR FLUENT 2 September 24, 2005 03:27
Model combustion KOchzg FLUENT 0 April 4, 2005 11:46
Combustion-which one is an appropriate model? Shankar FLUENT 3 February 16, 2004 16:57
