guys,
I need some help in setting up FLUENT for turbulent flow around circuler cylinder. I am willing to pay for this help. please its URGENT |
what is exactly the problem? well you can simply apply the desired turbulence model in define/models/viscous
no, for me its not that simple,I tried every thing
Spalart-Allmaras k-e k-w |
what is the problem exactly?
tell what is your problem and probably somebody can help...
the problem :
simulation of air around a circuler cylinder in wind tunnel D=2 in v=17 m/s I calculted Re its about (86,000) |
the problem :
Mike,
You seem to have a lack of knowledge. Don't say you have tried everything with k-w and k-e models... When someone ask what is your problem, dont answer what is the definition of your problem, but answer what is your problem (or error) in your simulation... I recomend u to read this: http://www.eng.fsu.edu/~alvi/EML4304...escription.doc But you will have to work, and not pay someone to do it for you... |
Urgent Help Needed! | Ken Adams | FLUENT | 3 | September 25, 2007 23:50 |
urgent help needed with 2d compressible flow | James | FLUENT | 2 | June 20, 2007 04:22 |
urgent help needed on dpm | vaishali | FLUENT | 3 | December 18, 2006 14:20 |
Urgent! Help Needed | Rucy | FLUENT | 0 | November 14, 2005 02:22 |
Urgent Help Needed! | Trias | FLUENT | 3 | June 19, 2004 07:04 |
