strange node values @ solid/fluid interface - help
Old   October 27, 2008, 12:38
Default strange node values @ solid/fluid interface - help
JB
Hey guys,
I'm modeling a heat sink (HS) operating in natural convection. Here is an overview of the model:
Geo + mesh: - one solid volume (al.), - one fluid volume (air), - hex elements in the solid, - tet elements in the fluid, - non-conformal interface between HS and Ambient Air (AA), - heat source at the bottom of the heat sink. - pressure outlet/walls/symetries to close my model (with correct backflow temp.)
Solver set-up: - laminar model, - gradient option: Green-Gauss node-based, - density: boussinesq model (-> steady state), - pressure disc.: body force weighted, - momentum/energy disc.: 2nd order upwind. (all other parameters left to default setup)
First of all, do you see some nonsense in my setup?
Here is my problem:
The 1st run used a quite coarse mesh, and gave a physically realistic solution. When plotting the temperature contours at the HS/AA interface, the facet contour looked great, and the node values contour looked a bit more 'random', but only oscilating by +/- 1 deg.C around facet values. so I thought: no big deal, this might be due to the non conformal interface, let's run the same simulation with a finer mesh and see what happens...
So I ran a second model, with the same setup but a finer mesh. The facet values were still very realistic, but this time, some nodal values on the interface are totally unrealistic (2 nodes in the same cell with a temperature difference of 400K !?)
From Fluent help files, I read that the node values are interpolated from neighbor cell values. But my cell values look ok (no crazy values when reporting min/max temp in the volumes). So what's happening? Is it due to the non-conformal interface?
Another thought was: I'm using the node-based gradient method... so I guess If my node values are wrong, this could affect the validity of my solution? (not only a post-processing issue, if you see what I mean).
For info, the mesh refinement significantly increased the temperature of my heat source (+10%).
Fluent Gurus? Any clue?
Thanks a lot in advance! /JB
Old   October 28, 2008, 07:18
Default Re: strange node values @ solid/fluid interface -
JB
anyone?
Old   November 1, 2008, 13:04
JB
up
Fluid - Solid Domain Interface Daniel CFX 6 February 15, 2009 19:09
Interface Fluid/Fluid and Solid Thomas Vanneste FLUENT 0 December 16, 2008 04:40
Setting Roughness on a Solid-Fluid Interface JensonButton CFX 1 February 7, 2008 14:41
BC at the interface of the fluid and solid manohar Siemens 3 April 8, 2005 12:34
fluid solid interface Alex CFX 1 February 18, 2005 21:55
