October 21, 2008, 13:42 |
pb with batch mode
hi, i'd like to use the batch mode but i have some problems. I want to make calculus for different viscosities of my fluid. I use: 1) fluent 3ddp -i test1.jou
or 2) fluent 3d -g <test1.jou>& testmoi & and my test1.jou is: /file/read-case test1.cas /solve/iterate 30 /file/write-case test11.cas yes /file/read-case test2.cas /solve/iterate 30 /file/write-case test22.cas yes /exit yes but when i use it it doesn't work... someone can help me please tkx |
October 21, 2008, 15:04 |
Re: pb with batch mode
You need to initialize your solution after you read your case file in batch mode.
use /solve/initialize/initialize-flow to initialize the solution and then use commands to perform iterations. |
October 21, 2008, 18:39 |
tkx i'll check that tomorrow and which one of these solutions should i take?
1) fluent 3ddp -i test1.jou or 2) fluent 3d -g & testmoi & tkx again |
Batch Mode | Titiksh Patel | FLUENT | 13 | February 1, 2010 15:48 |
batch mode | Peter Schaller | FloEFD, FloWorks & FloTHERM | 2 | October 6, 2008 04:18 |
Batch mode in WB. | cfdguy | CFX | 1 | June 24, 2008 07:49 |
Pre in batch mode | Kuts | CFX | 7 | August 17, 2007 06:10 |
DPM in Batch Mode | MM | FLUENT | 0 | December 15, 2006 14:17 |
