Dynamic Mesh Puzzle
Old   October 21, 2008, 09:33
Default Dynamic Mesh Puzzle
Paul
I am trying to simply rotate a square using the dynamic mesh feature of FLUENT. However, the mesh near the surface of the rotating square becomes scewed and negative volumes result. I have reduced the time step and am able to rotate ~50 steps (10 degrees) before the error.
The mesh is non-uniform (small near the rotating square and large near the boundary) and three dimensional. I am able to solve the problem in two dimensions with no problem.
Does anyone have any suggestions?
Old   October 21, 2008, 09:47
Default Re: Dynamic Mesh Puzzle
doki
Use size function, and change the remeshing/smoothing parameter values, set the spring constant factor as 0.
Some puzzle about the multigrid ztdep Main CFD Forum 6 May 13, 2007 02:52
A puzzle about turbulence of B.C. in inlet Yijin Li Fidelity CFD 3 May 2, 2007 22:31
Geometry/Trigonometry Puzzle RW Main CFD Forum 7 July 30, 2006 11:14
dynamic mesh - structured or cooper mesh Manoj Kumar FLUENT 2 November 11, 2005 02:18
A puzzle for the weekend? Robin Bornoff Main CFD Forum 2 May 17, 1999 04:17
