How to Plot Graph in Fluent ?
Like Tree7Likes
Old   March 20, 2016, 06:32
J_student is on a distinguished road
I am also trying to attain a pressure vs time graph however when i follow CeesH's steps and try to make the point surface in fluent the following error comes up.
Error: Surface creation failed!
Error Object: #f
I'm new to fluent can someone please tell me how to resolve this issue
Thanks in advance
niazgdc likes this.
J_student is offline   Reply With Quote
Old   March 20, 2016, 06:33
Error Object: #f
Thanks in advance
niazgdc likes this.
Old   August 15, 2016, 15:26
Default i need more answer on how to plot pressure time graph in fluent
  #23
Sucker
nwadikeamarachukwu@yahoo. is on a distinguished road
Originally Posted by CeesH View Post
Before running your simulation, go to monitors > volume monitors or surface monitors > set up a monitor point on the desired location > make sure you select "write to file" and set the desired axis values (iterations, time-steps or flow-time).
Volume monitors should be used if you want to know your value in a whole domain, or a part of the domain volume; so for pressure: if you want to know the average value over the whole domain.
Surface monitors should be used if you want to know the value on a plane, line or point. For pressure, you may want to know the surface-average value on a wall, or for a point, the vertex-average value. For this, you need to set up a new surface > point and enter the desired coordinates.
I am a new beginner in fluent. I saved my calculation activities in ASCII file which i created under Autosave Every(Time Steps). But when i opened it in excel, i could not see a column for time. All i saw was column for x,y coordinate and pressure coefficient.
Please i will appreciate if you will make it more elaborate to me on how to plot a graph of pressure against time. Am working on flow around high speed train in transient steady using inviscid solver.
Thanks for your human kindness.
nwadikeamarachukwu@yahoo. is offline   Reply With Quote
Old   September 3, 2016, 08:52
mahya
mahayheidari is on a distinguished road
how can i plot veloocity vs time?
please help me
mahayheidari is offline   Reply With Quote
Old   September 3, 2016, 08:56
mahya
Originally Posted by grisu
;154228
Correct - otherwise you have to use your saved files, load all of them using a script and process them, writing the results to files which you can combine.
please help me
Old   September 3, 2016, 09:03
mahya
please help me
Old   September 3, 2016, 23:49
Joe
enayath is on a distinguished road
Describe your problem better!
If you are using a steady state model, there is no time.
If you are using a transient model, simply go to "Graphics" and plot your simulation for a specific time.
If you wanna plot one variable as a function of time (which I think you want) you have 3 ways:
1- save the cas/dat file every time step( or every 2,3,...) and then open them via another program like Tecplot
2-You can set up an animation BEFORE running your transient simulation via "solution animations"
3- You can also save your data (variable and time step) via a ".out" file in "surface monitors" and then open it in Excel
Good luck,
Hooman
enayath is offline   Reply With Quote
Old   September 4, 2016, 05:12
mahya
Good luck,
Hooman
hello
thanks for your reply
can you explain third number more( step by step ).
because in surface monitor i cant have exact velocity in report type.I have average or max ,....
Old   September 4, 2016, 10:40
Joe
It depends on the type of information you would like to have, velocity of a point, average velocity on a line or a surface...based on that, choose the appropriate type ( like vertex average or area-weighted), select the point or surface or area,... and then run your simulation...for the detailed information, you need to read the Ansys Fluent Theory Guide ...
Good luck,
H
Old   September 4, 2016, 10:58
Default reply
  #30
mahya
Good luck,
H
if i want velocity of a point which is better to select
excuse me
Old   September 14, 2017, 03:32
Default transient simulations
  #31
Niaz
niazgdc is on a distinguished road
i hAve don transient simulations for 3 minutes and i have set monitors ,can i get concentration versus time graph in post processing? thanks in advance for help
niazgdc is offline   Reply With Quote
How to plot Shear Stress Graph in Fluent? Jane FLUENT 0 November 19, 2008 21:30
how to use tecplot to plot 3D graph? sam CFX 1 April 30, 2008 22:42
xy data from graph plot to excel Radhika Siemens 5 February 23, 2007 08:23
How to plot different model's graph on a graph? echo Siemens 1 April 28, 2006 04:54
graph plot anindya Main CFD Forum 2 September 17, 2003 13:00
