help or suggestion required -64 bit linux + gambit
Old   October 18, 2008, 06:39
Default help or suggestion required -64 bit linux + gambit
Ramesh.K
I get the following error message when i run gambit on my 64 bit laptop, /usr/local/Fluent.Inc/gambit2.3.16/lnamd64/gambit: error while loading shared libraries: libXm.so.3: cannot open shared object file: No such file or directory
I tried searching net. I am not an expert in linux
can any body tell me what to do
Old   October 20, 2008, 15:11
Default Re: help or suggestion required -64 bit linux + ga
Rajesh
Hi ramesh Did you set the path for fluent bin folder. If not, set using export PATH=$PATH:/usr/local/Fluent.Inc/bin
To start gambit, use the command gambit -X11
let me know if it helps.
Old   October 20, 2008, 15:14
Ramesh.K
Hi Thanks for ur suggestion but I dont konw I could find in one of the blogs a solution an i have install motif or something which spells like this I am sorry I dont remember it exactly and gambit started working
thank you for ur reply once again
Gambit installation under linux Alex Main CFD Forum 1 December 4, 2008 02:32
loading FLUENT 6.2 and GAMBIT on Red Hat LINUX Kiran FLUENT 1 October 16, 2007 10:12
Gambit error when running under Linux 10.0 Ralf Schmidt FLUENT 0 July 19, 2006 10:00
Gambit help required please Riaan FLUENT 2 January 27, 2006 16:46
What is the best Linux Version For Fluent & Gambit Tom Dutton FLUENT 2 February 6, 2005 14:19
