October 15, 2008, 07:48 |
Export command lines
Hi everybody,
Sometimes, I use Fluent for many cases, where I need to change some parameters only. So, I donīt know that, in Fluent there is a way to export the code in *.txt command lines to control it without GUI. I know that in CFX you can create a ccl file and open it with a text program to edit it. Thanks in advance |
October 16, 2008, 03:58 |
Re: Export command lines
Hello Isabel, this can be done by using a journal (.jou) file which contains the text-commands for setting the desired parameters. Generated once (file/write/Start Journal) you can easily edit this text file to set the appropriate values and read it back into a fluent session.
cheers Max |
Fluent Export Command Issue .... | Leo Hindarto | FLUENT | 0 | January 4, 2009 00:20 |
Where do the first several lines come from | lakeat | OpenFOAM Installation | 0 | June 27, 2007 11:35 |
gambit edge mesh ratio export command? | sophie | FLUENT | 0 | May 14, 2007 02:51 |
Command lines in Fluent. | pa-Hung | FLUENT | 10 | July 12, 2005 17:20 |
Text command of monitor-command? | Mika | FLUENT | 0 | March 27, 2001 14:46 |
