October 14, 2008, 17:04 |
Moving the geometry
How i can give at geometry, a move? For example, how i can designe a model of impeller of centrifugal pump which i must give it a rotative move?
October 15, 2008, 08:11 |
Re: Moving the geometry
the movement definition can be of some types. one of which, is moving reference frame, and defines the wall motion for a rotating frame. other types are done using UDF, etc. you can define the motion in the wall BC window, momentum tab, motion type as moving.
Moving Reference frame - UDF - Moving mesh | modisa | FLUENT | 0 | April 18, 2008 14:31 |
car geometry | Arjun | FLUENT | 4 | September 1, 2007 16:08 |
how to create a moving mesh geometry in gambit | Kannan | FLUENT | 0 | December 15, 2005 12:03 |
moving geometry leads to intersecting boundaries | CFD-novice | FLUENT | 2 | July 27, 2005 10:57 |
3D-geometry | shiva ram | FLUENT | 0 | January 17, 2002 18:00 |
