October 12, 2008, 09:44 |
import *.cas file to fluent
Hi all,im a fluent user and i encountered a problem when i imported a cas file into fluent.Message the fluent code generated is as follows: WARNING: no face with given nodes. Thread 2, cell 2065 Error: Build_Grid: grid error.
Clearing partially read grid. Error: Null Domain Pointer Error Object: () All ideas are appreciated Thank you very much in advance Ivan |
October 14, 2008, 08:34 |
Re: import *.cas file to fluent
As the error signal mentions, there must be a problem in the grid. May I know from where you've imported the '.cas' file?
October 14, 2008, 12:57 |
thx for ur reply
I imported the cas file in the file/read/case panel,and the cas file was generated from Gridgen. Please tell me what the problem is Thank you very much! Ivan |
Import solved data file in Fluent | dev.... | FLUENT | 0 | January 20, 2009 07:05 |
help on import mesh file into Fluent | hannah | FLUENT | 4 | March 3, 2008 15:32 |
Import a file into fluent - urgent pls help | Meenu | FLUENT | 4 | October 11, 2007 21:40 |
import *cas file from fluent to gambit?? | Rashmi | FLUENT | 5 | October 25, 2005 02:18 |
Import data from another .cas file of fluent | Umesh | FLUENT | 1 | August 17, 2003 05:51 |
