Velocity inlet boundary conditions
Old   October 8, 2008, 08:00
Default Velocity inlet boundary conditions
abm
Hello I am analysing the flow over an airfoil. But when I'm setting up the problem, this message appears: "WARNING: Velocity inlet boundary conditions are not appropriate for compressible flow problems. Please change the boundary condition types used for this problem" Then I can go on with the analysis, but I don't know what this problem means.
Thank you very much
Old   October 8, 2008, 08:21
Default Re: Velocity inlet boundary conditions
doki
velocity inlet BC type, should only be used for incompressible flows. if your case is compressible, change it to pressure inlet or ...
Old   October 8, 2008, 08:49
abm
But if I change it to pressure inlet, how can I simulate a 30m/s flow over the airfoil?? Thank you
Old   October 8, 2008, 08:56
Rok Sibanc
Set inlet as mass flow inlet and calculate it as: area * velocity * density
Old   October 8, 2008, 10:17
DANG Huixue
you can define the total pressure as: 0.5 * rho * velocity * velocity, just the same as the dynamic pressure
Old   October 8, 2008, 11:37
CL
Hi abm, Dont use mass flow inlet as ur boundary condition becuase for compressible flow density is not constant, so mass flow will not be constant for compressible flows.
With regards, CL
Old   October 8, 2008, 20:33
kartik
Hey You could use Pressure Far field. you can specify the mac number for the velocity you want to provide.
Old   October 9, 2008, 04:35
abm
Thanks to all. Now I have to try all your suggestions, and I'll post the results here. But I think that using mass flow isn't a good idea, as CL said before
Thank you very much
Old   October 9, 2008, 04:59
doki
mass flow inlet is of course one of BCs for the compressible flow, but in the case, I think using pressure inlet is more appropriate. pressure far field is something used only for external flow problems, and needs the outer boundaries of the domain to be very far from the inner boundaries. and also it is recommended for M>=0.6 in such cases. by the way, the pressure inlet appears to be more suitable for the case.
Old   October 25, 2008, 09:51
abm
I'm analysing flow around an airfoil near the ground, so I think I can't use pressure far field, and as it's about compressible flow, for me mass inlet is not a good idea. What do you think?
Old   October 26, 2008, 07:25
  #11
doki
for the condition, I think you have better use Pressure inlet/outlet conditions. It is a tough problem to encounter, i Know. But sometimes there is no other choices.
Old   October 26, 2008, 11:11
  #12
abm
What I don't understand is that, even with this warning, nothing wrong seems to happen, and the results are ok.
Old   October 27, 2008, 12:39
  #13
doki
well, yes. there are so many conditions which have the same problem. In many cases there are such conditions in which there is no errors. but when you are doing sth right, then the errors appear!
Old   October 29, 2008, 05:03
  #14
abm
The problem happens when I change material density from constant to ideal-gas. I'm trying to prove that the results are ok, instead of this warning
Old   August 3, 2012, 06:51
Default velocity inlet in fluent
  #15
hhh
kunar
hhh is on a distinguished road
Dear friends,
In fluent, For analysis of 2D naca0012 airfoil velocity inlet we give vcostheta in x component & vsintheta in y component, v is inlet velocity.
1)here i start analysis of 3D wing, for that i take naca 0012 airfoil & extrude 100mm, in gambit and analysis in fluent i have doubt how to set velocity inlet, here i consider my velocity is 50m/s, then what is xyz component,please let me know.
2)if you consider 3D wing, (vtantheta for z component) is correct or wrong, please let me know.
2) how to find angle of attack for 3D wing? please let me know
hhh is offline   Reply With Quote
Old   July 6, 2014, 06:03
Default Fluent physics Setup
  #16
Wing Boys
wingboys4 is on a distinguished road
We have created the mesh for B-737 wing using ICEM CFD. We have not been able to do the physics setup for fluent.
We want to use the following conditions:
Mach Number :0.3
We have tried using velocity inlet for inlet conditions, pressure outlet for outlet and pressure farfield for top and bottom surfaces.
We have tried to use SST K-omega model but there were divergence detected.
PLEASE HELP!!!
wingboys4 is offline   Reply With Quote
Old   October 18, 2014, 09:52
Michael Kruger
mich_K is on a distinguished road
If you specify pressure inlet as a BC, how do you attain a specified inlet velocity/Mach nr?
Also, when simulating flow over an airliner, would gauge total pressure be the ambient pressure at which the plane is flying, and what then would Supersonic/Initial gauge pressure be?
Michael
mich_K is offline   Reply With Quote
inlet boundary conditions mattia Main CFD Forum 0 February 11, 2009 07:06
pressure with velocity inlet boundary conditions Ashraf Sharara FLUENT 1 August 21, 2008 08:29
Inlet Boundary Conditions Fernanda Main CFD Forum 3 January 26, 2007 04:09
Velocity Inlet Boundary Conditions katy FLUENT 2 January 5, 2006 16:35
Velocity Inlet Boundary Conditions M.A. Rakib FLUENT 3 June 7, 2000 10:40
