can i set boundary condition in fluent?
Old   October 7, 2008, 21:57
Default can i set boundary condition in fluent?
edongliang
if i did not set the boundary condition in gambit ,can i set the boundary condition in fluent?how do that?
Old   October 8, 2008, 04:25
Default Re: can i set boundary condition in fluent?
dev....
Hi, As u said, yes you can define BC in fluent. If you do not define BC in Gambit, by DEFAULT it takes as WALL BC to each of the edges (for 2-D problem) or faces (for 3-D problem. you go to Define BC in Fluent, choose that FACE/EDGE (left panel)& on the Right side pannel you option of BC. if you want to define Vel Inlet, just click on Vel Inlet. 1 msg window will ask you to change BC. You choose YES. then you will get your desired BC on that EDGE/FACE.
Old   October 8, 2008, 11:09
edongliang
thanks you very much!you did not understand my problem. i mean add boundary condition not modify boundary condition ?anyone can help me?
Old   October 9, 2008, 04:15
joao
If yoy dont set any bc in gambit, then gambit will set a default wall bc for every face. But you can change them later in fluent, like dev said...
cheers
fluent boundary condition umesh kumar jha FLUENT 0 June 26, 2008 03:43
Fluent boundary condition jay Main CFD Forum 1 March 5, 2007 11:50
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
Boundary Condition for Fluent 4. Sanjib Das Sharma FLUENT 1 September 13, 2001 13:34
MHD boundary condition with FLUENT Damien Main CFD Forum 0 May 28, 2001 09:13
