hwo to import a *.neu file to gambit?
Old   October 7, 2008, 04:29
Default hwo to import a *.neu file to gambit?
edongliang
hi !
i had mported a *.neu file to gambit ?there is a error"the gambit file header (record1) is non-standard".somebody can tell me the reason?
Old   October 7, 2008, 08:49
Default Re: hwo to import a *.neu file to gambit?
shashi
yes pleae see format of neu file in gambit tutorial, then incorporate these change
Old   October 7, 2008, 21:53
edongliang
yes!i see format of neu file in gambit tutorial,and use the example of the tutorial,there are many errors.
why?
Old   October 8, 2008, 10:21
DANG Huixue
According to my knowledge, this file has a fixed format, you must write your files according to *.neu files's fixed format. Please check your file.
Old   October 8, 2008, 22:24
edongliang
thanks you !but my *.neu file was the example of gambit user's guide.
how can i import igs file in gambit? Javier FLUENT 2 May 23, 2011 11:51
STL file import to GAMBIT Spyros Stamatelos FLUENT 3 January 11, 2007 13:20
Import gambit file in Tgrid Elizabeth FLUENT 2 December 1, 2005 11:30
How to import PARTRAN file to Gambit?! anisa FLUENT 4 June 7, 2005 05:24
Import IGS file into gambit Burley FLUENT 2 July 11, 2000 18:41
